Results 1 to 16 of 16
Thread: ATF quantity?
    Dec 2018
    Metro Detroit
    81
    Default ATF quantity?
    Recently my 97 vic had a leaking transmission cooling line, was driven on it for a little bit and eventually lost all gears except for reverse.
    loaded it up with about five quarts so far and still only have reverse. Really hoping i just don't have enough fluid and don't have to rebuild or replace.
    now for the question: How many quarts of ATF should i need? I didn't flush the trans or replace the filter, just the cooling line.
    37,310
    What does the dipstick read? Needs to be checked with the engine running.
    Total capacity is near 12 quarts. I don't know how much can be lost before it completely stops shifting but losing that much fluid will not be good for it.
    Dec 2018
    Metro Detroit
    81
    reads full every time i pour a quart in, after letting it sit for awhile and letting it settle it reads dry again. checking in the morning to see if i need to add anymore.
    4,913
    If it’s not leaking out or getting mixed with antifreeze in the cooler at the bottom of the radiator, keep adding until you get a consistent full reading on the dipstick with the engine running.
    The wife did this to her 4L60E in her S10. The smell was horrible. Burnt nasty friction material smell. It recovered with addition of fluid (and leak fixed) for about 200 miles then left her stranded with no 3rd/4th.
    1988 Crown Vic Wagon - daily
    Dec 2011
    Yonkers NY
    3,817
    You add while the engine is running yes?
    Member EaOutlaw1969's Avatar
    Feb 2018
    353
    Also check both sides of the dipstick
    Dec 2018
    Metro Detroit
    81
    just checked the dipstick again and added a quart, still no movement. next up, change the filter. if it doesn't move then the transmission is getting torn out.
    Jul 2014
    Canada
    1,611
    I don't think changing the filter will get you anything at this point, except maybe for the sake of looking for transmission debris. When you put the fluid down the tube, it sits in the pan until the pump sucks it up through the filter. The reason you check it while running is that the amount in the pan should be at the designated level while the fluid is being circulated. The fact that the fluid is getting sucked up should not be surprising, and it would actually seem to be a good sign. At least it tells you the pump is still working. At this point, it's just a matter of how much more you need before you can see the fluid on the stick consistently and determine if the tranny still changes gears with the right amount of fluid.
    It's really a judgment call at this point. The torque converter alone requires something like 4-5 quarts. You've done six of 12, so you might only need 1-2 more or 5-6 more, and you might be screwed in any case. Not having fluid on the stick will certainly make taking the pan off easier, and changing the filter would be a good idea if you know the tranny is not toast, but would the extra work be worthwhile if the tranny is toast? If you don't change the filter and find the tranny is still good with enough fluid, you would lose 4-5 quarts of fresh fluid if you proceed with changing the filter. I'm not even sure what I would do at this point.
    Oct 2008
    St. Louis, MO
    411
    I think loosing 4-5 quarts of fresh fluid if the trans shows to be good is worth the cost vs. the time/money to R&R a whole trans.
    Are you checking the dipstick with it in park and running? Any other way will give a false reading.
    Dec 2018
    Metro Detroit
    81
    Quote Originally Posted by FordMan77 View Post
    have been checking it in park and running, still only have reverse.
    I drove it once or twice while the leak was present, never leaving my yard, soon as i realized i had lost all gears except for reverse and that the trans was losing fluid is when I left it to sit until about now. I've only got an acre of land so it's not like i did a whole lot of driving. I'm in an auto tech vocational class so as soon as I can get a trailer and a spot on a lift for a week or two I'll see what my options are.
    Dec 2018
    Metro Detroit
    81
    i've got a spot for a couple weeks. just need a way to get the car there and a transmission.
    Jul 2014
    Canada
    1,611
    I think loosing 4-5 quarts of fresh fluid if the trans shows to be good is worth the cost vs. the time/money to R&R a whole trans. ...
    Good point.
    Quote Originally Posted by frankenstang View Post
    have been checking it in park and running, still only have reverse. ...
    Was the fluid high enough to be consistently showing on the stick with the engine running? If so, then it's obviously not a fluid level issue, and I doubt the filter would be the issue. If not, then it's a matter of how much more you want to spend on fluid before opening it up or taking it out. I don't know the details of how things work inside trannys, but I do know it comes down to high pressure fluid being directed to particular areas to have particular effects. I learned that from a pump drive failing on a FWD vehicle many years ago. No fluid pressure = no workie.
    Dec 2018
    Metro Detroit
    81
    Consistently showing on the dipstick. assuming since i still have reverse that the pump is still functioning how it's supposed to. If i'm wrong please let me know, just dabbling into this platform as of right now. I'm getting everything together to begin the process.
    Jul 2014
    Canada
    1,611
    88grandmarq is a tranny expert who might be okay with you sending him a PM asking him to respond to this thread. AFAIK, if the proper level of fluid is sufficient to activate reverse, the pump should be good enough to activate the forward gears. The valve body is the part that directs the fluid where it's supposed to go, so theoretically there might be an issue in there, but that's beyond me. 88grandmarq is definitely the go-to guy.
    My screen name is GREEN, Bitches ! 88grandmarq's Avatar
    North Georgia
    2,194
    fluid capacity depends on torque converter size. models with 11.25" torque converter(police/HPP/sport/Marauder) take 13 qts to fill. models with 12" converter take 14 qts to fill. IF you remove the valve body from the case, it take 10 qts to refill the transmission.
    In the case of the original poster. if you have enough fluid, the dipstick reads full and you have no forward gears, you most likely damaged the Forward clutch. when this clutch fails you have NO forward gears, but reverse works fine. rebuild or replace the transmission
    Dec 2018
    Metro Detroit
    81
    Quote Originally Posted by 88grandmarq View Post
    thanks, guess i'll have a hell of a time doing that then.
