Results 1 to 2 of 2
Thread: Need an opinion on diff carrier damage
    GMN Regular Giraffe's Avatar
    Jan 2016
    Wichita Falls, TX
    812
    Default Need an opinion on diff carrier damage
    So the 28-spline I picked up from Pick-n-Pull earlier this year has some damage to one of the bearing race surfaces. I'm sure I don't need to worry about this, but wanted to get a second opinion. What do y'all think?
    óJohn
    1990 Mercury Grand Marquis LS (POTM March 2017)
    37,310
    Very carefully file the burrs off and you should be fine. Let the intact surface guide it, and use a fine file with not extremely high pressure. You'll feel when it stops cutting. Otherwise I wouldn't worry too much about it. It just needs to not have high spots that will interfere with pressing the bearing on or seating fully against the shoulder.
