Results 1 to 9 of 9
Thread: EATC Self diagnostic check error code
    I post a lot... porschpow's Avatar
    Dec 2009
    Hamilton, NJ/Flanders, NJ
    1,616
    Default EATC Self diagnostic check error code
    I want to know what the problems are if you have a code 031 on the EATC. I know it means the temperature sensor is open.
    What does this mean
    -1973 Volkswagen Bus Westy
    -1986 Honda Magna 700cc
    -2011 Subaru Outback
    37,757
    it means either the sensor is bad, or the wiring between the sensor and the EATC is damaged. Its the in-car sensor. Most likely the sensor itself is bad.
    Dec 2009
    1,616
    oh ok i believe the in car sensor is that little round thing to the right of the eatc (grill)
    Dec 2009
    1,616
    Where can you get this part. I was unable to find it on Rockauto
    Member WagonMan's Avatar
    Bridgewater Ct.
    461
    I have one from a 97 LTC Cartier I parted with 75Kmiles. VEIGHTPETE@GMAIL.COM
    1990 Colony Park
    1970 HEMI Superbird
    Member EaOutlaw1969's Avatar
    Feb 2018
    357
    Does the Heat- A/C work normal during manual mode?
    Are you getting cold or hot air discharge during automatic temp mode?
    Temperature discharge in Automatic mode should dictate which diagnostic pin point test you would do and it may also dictate which part or wiring etc could be bad faulty open shorted etc.
    I like to diagnose problem before buying and or waiting for parts that may or may not fix the problem.
    This link gives you a idea of what I am going on about. ( which may or may not apply to your ride )
    http://www.fixya.com/cars/t26925593-...ing_code_31_in
    Dec 2009
    1,616
    The heat works well. The weird thing is that it throws the cold only when it's cold out, like real cold out.
    Haven't tried the A/C yet, so I don't know how well that works
    And I rarely put it on automatic mode.
    I will look at the link that you gave. Thank you for your help!
    37,757
    from here
    http://www.idmsvcs.com/2vmod/eatcswap/selftest.html
    "The vehicle interior temperature should be between 4-32C (40-90F) when carrying out the self-test. If the temperatures are not within the specified ranges, false in-car temperature sensor DTCs will be displayed. "
    so faults only when its cold outside probably don't mean anything.
    Dec 2009
    1,616
    Thanks! Look like today I won't be able to do anything anyway!
