90-97 Tailpipe Hanger Question
    I know up to 89ish the tailpipe uses two bolts to attach to the hanger.
    I know my 90 wagon has a newer style rod on the tailpipe which goes into a rubber isolator and bracket. Are the sedans a similar setup?
    Clarifying with some generic google pics. Ignore surroundings and focus only on pipe to hanger attachment...
    Pre-1990 attachment technique:
    Possible 1990 to ? Technique:
    Is the second picture similar to 1990+ sedan on the rearmost tailpipe hanger?
    I am considering purchasing a left sedan tailpipe to modify into the long factory dual style for the wagon. The 1990 sedan pipe is more expensive by a few bucks and I will spend it if has the correct hanger I can salvage to use on the existing dual hanger.
      I do know there is something similar to the bottom picture on my '90 GM. However, the exhaust shop that did my duals didn't use it and just welded a universal bracket onto the frame.
      —John
      1985 Ford F-150 XLT Lariat
        Here is a side by pic of the wagon vs. sedan. Same location, wagon uses two bolts where the sedan uses one bolt and a tang. Wagon is wider and heavy duty compared to the sedan. WagonMan
        89 Colony Park
        90 Colony Park
        70 HEMI Daytona Convertible
          Thanks to you both. Going to order the sedan tailpipe and see if I can modify it to look like a stock wagon version. Have the hanger already luckily.
