My 1997 Marquis got an inspection but I changed my battery about a month earlier and now the monitors are not ready. This is really driving me nuts. Is there a way to expedite this process. I just spent 2 days just driving this car around and still 4 monitors not ready. Please help!!
Rejection inspection
Normally that stuff resets within 50 miles. What isn't ready after a month?86 Lincoln Town Car (Galactica).
There are several individual monitors that must complete testing to pass. If we knew which specific monitors were incomplete it would help.
Did the inspector tell you which ones were incomplete and do you have a code reader available to you?
Does autozone or any similar place offer a free read?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
It needs temp cycles as well. Should be 8 temp cycles IIRC. This means full warm up and closed loop driving for a while. Then you need to have it cool down below closed loop temps. This should take 4 days of normal driving typically. (to work, from work routines)
Hello I finally found the specific for monitors that are not resetting for me on this 97 Marquis it is the catalyst monitor the EVAP monitor the oxygen sensor monitor and the oxygen sensor heater monitor if you could give me help with these anyway would be totally appreciate it cuz I'm pulling my hair out with this thank you and have a Merry Christmas and a Happy New year03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by jaywish View PostHello I finally found the specific for monitors that are not resetting for me on this 97 Marquis it is the catalyst monitor the EVAP monitor the oxygen sensor monitor and the oxygen sensor heater monitor if you could give me help with these anyway would be totally appreciate it cuz I'm pulling my hair out with this thank you and have a Merry Christmas and a Happy New year
I saw some strange posts from Jay's account the other day too. Looked at it and the IP address seems logical but something definitely seems off86 Lincoln Town Car (Galactica).
You guys are right I have been making strange posts but y'all should expect that on occasion from me. I will attempt to resume my normal posts as soon as possible.
The info here is from mgm6397. So have at the monitor issue.
I can't for the life of me remember how much fuel should be in the tank for the EVAP monitor to set.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
I'm guessing PM sort of deal where you figured someone else might be better suited to answer the question. That would explain the post in this thread, I was also wondering what was going on. Anyway, I'll butt out now, I don't actually have anything useful to add for the OP.Vic
