Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: The Odissey continues: Fuel pump for a 1987 Colony Park?
    Default The Odissey continues: Fuel pump for a 1987 Colony Park?
    Hello Guys!
    I posted a thread some time ago about the sudden shut off of my 1987 Mercury Colony Park, specially while the car was in movement...well, I leave the car with my mechanic and the problems on the engine were bigger and bigger, so I take the option of a complete engine adjustment. After 1 month of work and looking for spare parts (not so easy to found in Chile), the car was finished, but it still shut off!!!
    Many parts were replaced or repaired, including change of gaskets, IAC Valve, fuel pressure regulator, water pump, etc...
    Now, the mechanic says that the fuel pump, which has 14 months of use, has no pressure to work properly. The fuel pump was an "Autobest" found at ebay. This is my last resource to solve this problem, so, if eventually the current fuel pump only has 1 year of life, I want to buy a good one now.
    I found the fuel pump with the hanger:
    https://www.ebay.com/itm/Fuel-Pump-H...53.m1438.l2649
    Is "Sprectra Premium" a good maker for this part?, and has this hanger any relation with the fuel level reading?, which is broken on my car too...
    My other option is only the fuel pump and strainer, maybe a Bosch?
    https://www.ebay.com/itm/Electric-Fu...53.m1438.l2649
    What do you recommend?. Or of anyone can tell me which is the proper spare part to solve the problem of fuel level reading too...I appreciate your help!!
    4,802
    I have been using the spectra premium one in my 90 for the last year. I haven’t driven the car much but it has worked fine so far. I bought it because it’s the only one that came with the hanger, which I needed due to a very bad fuel tank from sitting ten years. You shouldn’t need the hanger, so you can get just the pump. The Bosch one you listed is a good choice in my opinion.
    The fuel lever sender is separate. They are pretty simple things. Maybe just needs a new float or the contacts cleaned. If the circuit board is bad, then you can substitute one from a sedan up to 1989 or so.
    1988 Crown Vic Wagon - daily
    36,864
    I do not believe the fuel hanger for a sedan works on a wagon. I don't believe that part will fit your car correctly, but I do not own a wagon to say this with absolute certainty.
    For whatever it may be worth, I fitted a Walbro pump for a Mustang to my original hanger in my 86 Towncar. The Mustang pump is smaller diameter, so it has a hose clamp holding it to the bracket. Its been fine for nearly 10 years now.
    Sending unit can usually be cleaned. It has a plastic cover that opens, and inside is a board with a wiper contact hooked to the arm. Carefully clean the corrosion from the board and wiper. Be gentle with the plastic, it gets brittle. If the float is sunk, its a common float used on many Ford products.
    Thanks for your advice, guys.
    Today the fuel pump was changed, the problem still remain.
    The engine shut off when idling, when I stop on a cross or the run is just erratic.
    I change many parts, spent a lot of money and feel that I'm giving up with the car .
    Probably, if I live in. The States, the problem would be solve now. I don't know what to do...
    4,802
    I reread your original thread on the problem. Seems you have a new Motorcraft IAC which should be okay.
    Have you checked for codes? Here’s how: http://www.grandmarq.net/oldfuelinjection/page13.html
    I think it would be wise to set the base idle. With the engine warmed up, all accessories off, and the IAC unplugged, set the idle to 750rpm. That sets the base idle. Then plugin you IAC.
    Could be many things. Hoping the computer can point us in the correct direction.
    previously known as T65neon5
    Feb 2016
    94
    has anyone checked the MAP sensor?
    I'm not completely oblivious to reality, I just choose to reject it when it doesn't line up with my opinions. (thanx Thain!)
    Apr 2015
    Southern Commiefornia
    2,016
    Like the others said, lots of things it could be aside from fuel pump. Could be an issue with ignition, especially TFI or uh, hall-effect sensor? WTF is that thing called?
    36,864
    the PIP, Profile Ignition Pickup.
    Does it produce any codes if you check it with the engine running?
    Birdsboro PA.
    16,925
    either that or the map sensor vacuum hose is collapsed or has a hole in it.
    Is hard to get a scanner for OBD1 Ford here in Chile, since these cars were not so common at the ´80s. American cars were more popular from the ´70s and before and after that, the japanese and european models rules the market until today.
    I order a scanner for Ford models at Amazon:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Anyway, I will try to follow the instructions to scan the computer without the scanner.
    For the record, here are the parts that has been replaced for new ones:
    -TFI
    -ignition coil
    -Voltage regulator box
    -Spark plug wires
    -Spark plugs
    -Fuel pump (with tank flush)
    -Fuel pump relay
    -Fuel filter
    -Almost all the engine gaskets
    -IAC Valve
    -Almost all the hoses of the engine.
    And maintenance to almost all other components of the car (water pump, radiator, steering pump, brakes, etc...)
    "Check engine" light never turn on, but it does when I turn the key for ignition (like almost every car), after that, it turn off.
    36,864
    You can use a test light to get codes
    just count the blinks.
    Quote Originally Posted by Bad-Driver1 View Post
    MAP sensor is located on the firewall on the passenger´s side?
    If I remember correctly, the hose was replaced recently, but the sensor is the original from the car.
    20,468
    double check the hose to make sure nothing has damaged it and that it's still installed. Though the MAP sensors rarely go bad, they do go bad. But do check for codes as that may well let us know what is wrong.
    I will, thanks!. But I don´t trust on my capability (or my mechanic) to count the flashes So, I will wait the machine I ordered or find another scanner locally.
    Besides the MAP sensor, is there another sensor which could cause a similar Symptom? (the engine stop at movement or idling).
    If I can. I prefer replace all the sensors that could go bad....after all, most of those parts has more than 32 years!
    36,864
    The digital display is a nicer way of doing it. I have one myself, but the ABS system in one of my cars won't use it and I don't want to spend the money on the special Ford tester. My solution is a jumper wire and counting the blinks.
    Maybe the ignition pickup. They get funny when they start to die. If you can get a complete distributor, that might be easier than just the pickup. The distributor has to be taken apart to get the pickup out.
    For the record, I change the TFI for a Motorcraft 1 year ago. About 1 month ago, when the problem gets bigger, my mechanic says that the TFI went bad and put another module (not original). The problem was apparently solved, but the stall and shut off persist a couple days after the replacement. Could this being produced by the bad PIP?, I mean, the defect on the Motorcraft module.
    36,864
    The PIP is down inside the distributor. Its not the TFI, but it drives the TFI. They can get funny with heat. No guarantee its your problem.
    and I believe that is the correct pickup.
    Is the timing properly set? If its not done right, the engine might stall. Vacuum leaks also tend to make it stall. It might also surge a lot. Temperature sensors that are bad might do it.
    http://www.grandmarq.net/oldfuelinjection/page10.html
    If the EGR valve sticks open that would also make it want to stall
    bad MAP sensors make them run pretty terrible too
    Can you get a video of how the engine runs? That might help
    I really just hate to tell people to throw parts at problems.
    Ok guys, I got the code reader today, and the results were:
    in KOEO:
    23:Throttle position sensor signal out of range?
    34:EGR Problems?
    in CM:
    18: Loss of tachometer input (the car doesn´t have tachometer on dashboard), IDM circuit failure or SPOUT circuit grounded. it doesn´t sound good...
    34: same EGR Problems?
    in KOER:
    21:Coolant temperature sensor. (where is located?) I think I´m confusing it with the dashboard temperature sensor, which my Colony Park has no light.
    23: Throttle position?
    41: HEGO (HO2S) sensor voltage low. Is this referred to the oxigen sensor?
    91:HEGO Sensor voltage low
    and 34, again...
    I´m a bit lost with all this info. If I understand, the EGR needs replacement, also, the engine coolant sensor and the oxigen sensor need a replacement too...
    But which one of all those problems could be the main problem of engine shut off?.
    I remember about the code 18 is a terrible code in another thread, is it?, the car is death?
    I already bought a new EGR, MAP sensor (just in case), new PIP and distributor cap and rotor...
    Hope your wisdom could help me!!
    36,864
    KOEO
    23 - bad throttle position sensor most likely. This will cause a lot of stalling and running issues
    34 - egr, could be a lot of things, but it won't cause the engine to stall
    CM
    18 - this usually means the connection between the coil and the ECM is open. There are two green wires at the ignition coil. One comes from the ignition module, the other goes to the ECM through a resistor. If both of those wires are not connected, you'll get this.
    34 - see above
    Just a note, the CM codes just mean this happened at some point. It may not be an ongoing issue. Usually I'd suggest clearing these and checking to see if it comes back. If it does not, call it good.
    KOER
    21 - was the engine warmed up? If not, you will get this code. If the engine was up to temperature, the sensor is in the fitting where the heater hose attaches on the passenger side of the engine. Its a 2 wire sensor.
    23 - TPS is bad
    41 - oxygen sensor reads lean. This may be a vacuum leak, or it might be a problem related to the smog pump. Try removing the belt from the smog pump to see if it goes away
    91 - same thing, other side
    34 means the EGR is either stuck partly open, or the sensor is bad. Unplug the green hose to see if it has vacuum on it. if it does, the control solenoid is bad. Leave the hose off and re-test, you should get a code 33. If it does not, remove the valve and make sure there is nothing holding it partly open. If it is closed and not getting vacuum, the sensor is probably at fault or the wrong one. I have fixed this by lightly filing the end of the position sensor until the reading is correct. The valve MUST be fully closed though, or the engine will be prone to stalling.
    Based on your codes, I'd replace the TPS and check the EGR valve first. Clear the codes once you fix those two problems and see what comes back. If the engine was warmed up, replace the coolant temp sensor too.
