Results 1 to 9 of 9
Thread: brake/turn signal
    Default brake/turn signal
    Whenever i set my turn signal for a right turn my right rear turn signal flashes aswell as the third brake light, has any one ever had this issue? Id just like to know how to fix it, thanks.
    4,800
    Welcome.
    Is this an 85 (going by your user name)?
    Did it just start this or has it been doing it as long as you owned it?
    An 85 should not have a third brake light unless it’s very very late production. Possible someone added it. Take a peak at the wiring to see if it’s factory.
    1988 Crown Vic Wagon - daily
    36,862
    If someone added the 3rd incorrectly by tapping off the RH brake light, it will do this. There really isn't any other way to make a third brake light flash. Its supposed to feed directly off the brake switch, where the two tail lights go from the brake switch through the turn signal switch and then out to the lamps. Thats how it switches from steady on bright brake light to flashing bright turn signal. Fair bet someone didn't want to run a wire all the way up front under the dash so they cheated.
    thanks for the replies, the car has been doing this since ive owned it and based on the replies ive recieved ill be wiring this directly to the brake switch, thanks again.
    Mar 2007
    North Las Vegas Nevada
    2,175
    You now have a turn signal that other idiot drivers will see and won't ride your tail and be assholes.
    36,862
    hah, you're funny. You actually think people pay attention to the cars in front of them.
    Member EaOutlaw1969's Avatar
    Feb 2018
    304
    I worked on a Caddy Eldorado Years ago that when the brakes were applied every light came on all the turning signals, parking lights indicators, etc.
    All because someone put in a single element 1156 bulb where a 1157 dual element bulb was needed.
    I agree check the basics look for modified wiring then if needed make sure the correct bulbs are installed.
    so i tried to wire in the third brake light properly, but the issue is there are two green wires after the brake pedal switch, and i dont know which one to solder into. some assistance would be appreciated, thanks
    36,862
    Light green is the switched output. Light green / red is the constant + in.
