Best AOD Rebuild kit?
    Guys. as you can see in other sections of this forum, I have continuous problems with my ī87 Colony Park!
    Here are the other threads:
    http://www.grandmarq.net/vb/showthre...524#post824524
    http://www.grandmarq.net/vb/showthre...uring-movement!
    While Iīm trying to solve the shut off problem, It seems that mechanics donīt reconnected in proper possition the pipes of Automatic transmission fluid, so the Mercon V ended on the pavement...
    Despite the oil (which was changed 1 year ago) was refill (iīm not sure if with the correct quantity), I have the feeling that they kill my transmission because the car was move in that condition (only bad experiences with mechanics!).
    Now I tried to go back and the reverse doesnīt work properly, and on "Drive" tha car makes some "jumps" or the engine stalls (I donīt know how describe it, but it could be related to the shut off problem) also it has a leak of lubricant since I bought the wagon 2 years ago, but the level of oil was always the correct (thread here):
    http://www.grandmarq.net/vb/showthre...c-Transmission
    so Iīm plannig rebuild the transmission with an expert, but I need the most complete and proper kit to import it to Chile. Anyone can tell me the best brand for a rebuild kit or which one is the best to solve my problems definitely?
    I was looking at the pioneer website and I found 3 codes for a ī87 Colony Park:
    -752027
    -753013
    -753014
    Anyone has experience with this kit or any other?. Please, let me know your opinions!
    Unfortunately, the end of the year has been only bad experiences with my wagon and mechanics, but I donīt want to quit yet!!
    Thanks!
    I very much doubt the transmission is causing the engine to stall. If you have 4 forward gears and it shifts between them, you probably do not need to rebuild the transmission.
      It sounds to me like the fluid is low. When its low enough the car wont move until you give it some gas and it jumps forward (or back if its in reverse).
