Wiper Motor before I proceed:-)
    Ok gang, the NOS in the box one wire wiper motor arrived to day.....for my '86 MGM Tudor.
    Before I delve into it's installation, is there anything I should be aware of in the removal of the old motor?
    Thanks in advance for any and all thoughts and suggestions.
    Happy new year to all!!!
    Don't drop the clip if you don't have a spare.
    Getting the clip off is honestly the hardest part, and its not that difficult. It has a lock tab on the top, you'll need to use a small screwdriver to lift it enough to slide over and release. Its basically just a keyhole opening with a tab to keep it from falling off.
    Clean out the cowl area while you're in there. May as well get the leaves and gunk out.
      Many thanks Thain!!
