351W Engine Mount Bolt/Thread Size?
    1/2" - 13?
    ARP engine mount bolts I got are unidentifiable at the moment. My ARP bolts thread half-way and bind up. The engine mount bolts I took off of the lopo are 1/2" - 13 and thread right into the 351W engine mount holes. Gonna go to my local hardware store and get the hardest bolt of that size. Just want to confirm though, before I do so.
    I'd just take the one that threads in to the store. They'll match it up.
      Pretty sure the stock bolts are flange head, which the hardware store is not likely to have. McMaster-Carr has them, or Fastenal may. If they don't they should be able to order them in. Just match the stock hardware. Or re-use the original hardware since its not something that really goes bad.
        I can get a hardened washer with my bolts; would that work? That's what I have been doing with most of the other hardware.
          Never knew ARP made engine mount bolts, and I ordered just about all of their parts I could for my 408. I reused stock hardware for the mount and it's held just fine
          '80 Town Coupé
            I suppose a washer would work in place of the flanged head, but its definitely not as easy to install. The flanged heads usually have teeth to help hold them too, which isn't a bad thing.
            guessing ARP doesn't sell them for that task, it just happens to be a bolt they make that fits the hole.
