Results 1 to 8 of 8
Thread: Window motor and regulator
    Default Window motor and regulator
    I have a 85' 2 door crown vic, where can i find a motor and regulator?
    rock auto only sells the motor, any assistance would be appreciated, thanks
    18,452
    Highly doubt it would exist as a kit. Will have to find separately. Don't know if regulators are the same between two and four door models. Will have to scour the internets and junkyards for a replacement most likely.
    Which side are you looking for?
    I post a lot... Toploader's Avatar
    May 2013
    1,683
    Good morning 'Crown'!!
    Here is the part number you will need!
    E3AZ-54233V95-ARM.....this is the motor and the regulator. Was still available via the FoMoCo parts system at your local dealer upon order.
    Good luck
    thanks for the part number, I just want to have these for both doors, as its getting hard to find parts for these cars.
    Member WagonMan's Avatar
    Bridgewater Ct.
    439
    I have a FORD crash guide. Part#s for the 2-door regulator 79-87 are D9AZ 6623208-A passenger side and D9AZ 6623209-A for the drivers side. (motor not included). 4door part#s 79-91 are E9AZ 5423208-A passenger and E9AZ 5423209-A drivers side.
    Good luck. WagonMan
    1990 Colony Park
    1970 HEMI Superbird
    37,506
    Is the regulator actually damaged? Its a big metal contraption, and rarely has any failure unless someone did something stupid to it. Usually about all it needs is the guide bushings replaced.
    GMN Regular Giraffe's Avatar
    Jan 2016
    Wichita Falls, TX
    817
    The roller that goes in the window track was broken and missing on the driver's front window regulator when I bought my car. Assuming this is your problem, there is a replacement roller kit you can get.
    Part number is D6AZ-5323240-A
    óJohn
    thanks for the help everyone
