Results 1 to 11 of 11
Thread: Small fuse/relay box OEM look?
    18,232
    Default Small fuse/relay box OEM look?
    I am looking to find any info around a compact relay/fuse box available from JY cars. Kinda looking for a few fuses and maybe a couple of relays.
    I will likely be installing something that needs a fused source and I think my p.side fuse box (I have converted to areo fuse box)is maxed out not to mention I dont want to run it all the way there when the item in question will be mounted right under the brake booster.
    I have the fancy Lincoln bracket that bolts to the air boxs' rear most studs and originally holds a set of four relays. I will be likely using that bracket/modifying it to work with some fuse/relay box that is not too big.
    Below you can see the 4 banger relay box behind the air box....that is the location I will be installing a new relay/fuse box if I can find one...
    This is the location on my car where I would like to stab it all.identical to the Lincoln location..just behind the air box.
    I like factory looking add ons as you may tell (for the most part) from my engine bay picture. Any help,suggestion and tip are appreciated.
    18,232
    This is something along the lines of what I am after:
    https://www.ebay.com/itm/MICTUNING-1...iY:rk:144:pf:0
    Price is hard to beat too. JY would want 10 bucks for fuse box....
    36,998
    Not a bad price, and with the terminals you can make it completely custom rather than having to splice anything. Do you have one of the crimp tools that makes the M crimp for those style terminals? If not they're not too spendy. I have one that I use with OE type terminals for fixing stuff.
    20,540
    Here's that same bugger on Amazon: https://www.amazon.com/MICTUNING-12-...dp/B075M4PRG2/
    $20 for the waterproof version. https://www.amazon.com/dp/B07MR64XK1/
    Amazon has several options: https://www.amazon.com/s/ref=nb_sb_s...ox%2Caps%2C171
    36,998
    extra few bucks for waterproof seems like a good value.
    18,232
    Well I have a proper crimp tool with multiple dies on the way now.
    I agree, that waterproof one is a great deal but the orientation of it will not work for me. Luckily I dont do any underwater driving or any water driving so it won’t make a difference. Stock ford one from aero models are non waterproof. I think I will be just fine. I placed an order for the non waterproof box and we’ll see how she goes. Just a little bracket would need to be fabbed up holding the new fuse box and I will weld that to the stock lincoln bracket and it should all sit the way I want it to.
    Still open to oem suggestions anyone may come up with.
    GMN Regular Giraffe's Avatar
    Jan 2016
    Wichita Falls, TX
    766
    I did notice when I was at the yard last that later model OBS F-150s have a much larger fuse box than a panther. Might be something to look into.
    —John
    1990 Mercury Grand Marquis LS (POTM March 2017)
    18,232
    Maybe that is something I should have started with, a larger fuse/relay box to begin with. No way in heck I will be pulling out whats there and replacing it with something larger. My aero one just fits as is. I also like the idea of having some fuses/relays available to me on the other side of the engine bay.
    20,540
    late Cougar fuse box is also rather large. Uses the smaller form factor relays though, but they're common now.
    Stow It! GM_Guy's Avatar
    Ontario, Canada
    3,136
    That MICtuning fusebox looks nice, even more amazingly, only $17 canuck bucks at amazon canada.
    The only small autowreckers fuse box I've ever seen is the secondary one out of the 91+ panthers. The only other small, rectangular box without oddball moldings would be the in-cabin late model panther box (18 mini fuse locations, 6 large, one relay).
    18,232
    It is quite nice actually. I started working with it today:
    http://www.grandmarq.net/vb/showthre...l=1#post824904
