Results 1 to 20 of 20
Thread: Stiff steering
    I post a lot... porschpow's Avatar
    Dec 2009
    Hamilton, NJ/Flanders, NJ
    1,616
    Default Stiff steering
    Good Morning all and Happy New year!
    I have a steering question an wondering if anyone else has been through this.
    My '97 Lincoln Town Car has been having stiff steering. I am no longer able to turn the steering wheel with ease with one hand (one finger turn). I have been noticing that even and real cold mornings when I go to work, the steering is incredibly stiff! After making turns the steering wheel does not return back (only returns 25%) . The rest of the way, I would have to assist back to normal.
    -1973 Volkswagen Bus Westy
    -1986 Honda Magna 700cc
    -2011 Subaru Outback
    Jan 2007
    Westmont, New Jersey
    10,269
    Could be an alignment issue. Returnability is a caster thing. Inspect your balljoints and whatnot.
    Vicky
    Blue
    Gone! But Parts from it will live on in others!
    Dec 2009
    1,616
    Yeah, What I suspect is
    -what you said
    -Power steering pump could be going
    -power steering pressure switch could be screwy
    Jan 2007
    10,269
    Quote Originally Posted by porschpow View Post
    A pump would not cause a wheel returnability issue, by that point the vehicle is rolling and the alignment should more or less make it return to center as you drive.
    Stupid question, is your variable assist steering setting switched all the way up?
    Vicky
    Blue
    Dec 2009
    1,616
    Not a stupid question at all. I have been reading up on that. Apparently the switch is next to the oil filter and is prone to screwing up from the road grime. I usually leave it at the low setting.
    A separate question, I have to replace the pump anyway since it leaks, what Power steering pump should I stay away from
    Jan 2007
    10,269
    A leaking one. Go with Cardone or Motorcraft.
    Vicky
    Blue
    37,773
    Sticky U joints in the steering shaft will also make it do this. The 90s cars seem prone to having them rust up.
    Apr 2015
    Southern Commiefornia
    2,116
    Good info guys. I've noticed the steering on my current '90 is much stiffer than the other one was.
    Dec 2009
    1,616
    POWER STEERING pump i'm guessing is original as far as i know. I never changed it since I had it (almost five years ago).
    Has 123,000 miles on the car.
    I still need to lift the front end off and steer the car left and right to see if it is not stiff (tie rods/ball joints) (WITH THE CAR OT RUNNING OF COURSE). I also sprayed the shaft (up and down) with pb blaster and silicone. It got a little better but barely noticeable
    37,773
    Not sure I've ever had a PS pump get noticeably weak, usually they just leak or get noisy. Mostly the noise comes from wear, which happens when the leak causes them to run really low on fluid.
    Dec 2009
    1,616
    As John said, the returnability issue wouldn't seem to be from Power Steering, Although my power steering seems to be leaking from the underside. Seems to be coming from the power steering pulley area. However I notice when I go to take on/off ramps with the steering wheel turned, the steering wheel would almost pulsate (meaning it would be a smooth turn of the steering wheel
    37,773
    that honestly sounds like U joint binding or a failing bearing in the steering column. Usually if the PS pump is ailing it will only give you trouble on rapid wheel movements like parking. Unless its sucking air, in which case it'll do generally stupid things.
    Dec 2009
    1,616
    I'm assuming the bearing in the steering column is in the firewall?
    Also, i may believe you're right. I notice it especially in the cold weather that as a turn the steering wheel, i notice resistance and then all of a sudden, the resistance is gone and the steering is easier.....Weird!
    I did change the shaft above right by the firewall and i did spray the lower shaft knuckle with pb blaster followed by white lithium grease
    Dec 2009
    1,616
    The bearing in the steering column, can that be accessed from the cabin or from under the hood?
    37,773
    inside the car. The lower one might require removing the column to take it apart though. I've never had to change one myself, I just know that it has bearings in there.
    Dec 2009
    1,616
    Is there a way to check those steering column bearings to see if they are still good?
    Is it possible to get a grease gun in there (with a needle fitting) to service it?
    Dec 2009
    1,616
    Ok, Update. I managed to get the shaft off (intermediate) and the U joints were fine. HOWEVER, the bearing that resides in the firewall was stuck on the steering shaft race to the point that the steering shaft and bearing were spinning as one unit and treating the rubber grommet as the bearing. I managed to get the bearing off. It seems as the shaft (around the plastic race) swelled to the point that it restricted rotation of the bearing. WEIRD!
    On a different topic, I notice that the steering shaft by the steering box cannot be bought. However I did notice some play in the rubber puck. How have you guys fixed this?
    Member WagonMan's Avatar
    Bridgewater Ct.
    461
    I don't believe its a bearing. I am pretty sure its a bushing/sleeve. I have one from a 97 LTC Cartier I parted with 75K miles. Feels smooth and U joints work fine, A little rusty on the firewall side, but works fine. VEIGHTPETE@GMAIL.COM
    1990 Colony Park
    1970 HEMI Superbird
    Dec 2009
    1,616
    Hey! I tried to upload the pic, but no dice.
    The part you have a pic of is what I took out. Housed in that rubber grommet is a needle pin bearing that is supposed to rotate freely around the shaft. Mine didn't the bearing was permanently fixed the shaft
    Dec 2009
    1,616
    IS there any way to fix the lower shaft (rubber puck). I definitely feel play there
