Results 1 to 12 of 12
Thread: Hubcentric spacers on the front
    Jun 2006
    Holland,MI
    353
    Default Hubcentric spacers on the front
    Well all know they dont fit on old style rotors... unless you do this
    37,752
    my lathe doesn't have the swing to mount the rotor, but I can bore out the spacers easy enough. Haven't run stock rotors in a long time though, and my two Fox cars that do use those rotors run stock wheels.
    18,579
    Nice! Machining things is fun. What wheels you planning to run?
    Jun 2006
    Holland,MI
    353
    Problem with boring the ID of the hubcentric part of the spacer is that the wall would end up being about .0075" thick by the time it would fit over the rotor stub. I found some cheap 16" LSC turbines in pretty good shape that were just spray bombed black. my buddy is blasting and powder coating them (it's his actual job, he works for a powder coating company)
    Hobbit
    Dec 2006
    Ontario, Canada
    1,264
    Couldn't you just get the spacers made that fit?
    Jun 2006
    Holland,MI
    353
    Still, that hubcentric wall would only be .0075" thick. The pass through diameter on the spacer is 2.545" Stub on the rotor is 2.760" Hub mounting diameter is 2.780" (70.6mm)
    Jun 2006
    Holland,MI
    353
    Wheels came back from powdercoat. They look way better than i had thought they would
    37,752
    Looks good. Nice option for LSC wheels that the finish is getting a little ratty on.
    18,579
    Does look nice. Get them installed.
    21,039
    Nice
    Someone on the LincolnsOnline forum directed me to this thread for help and answers. Is that correct saying that you're in Holland, Mi? Not being creepy, just might need some machine work done and I live in the GR area.
    Jun 2006
    Holland,MI
    353
    depends on exactly what you need, i may be able to help. This is just clearance, it's really absolutely not precise. The diameter i turned is not perfectly concentric with the hub diameter. I just slapped it up on the chuck and cut some matl away. If you need precision these junker lathes we have at work probably wont do it.
