Results 1 to 13 of 13
Thread: 2000 GM alloy wheels on a 1989 CV
    n00b
    Jan 2019
    Lakewood, CA
    9
    Default 2000 GM alloy wheels on a 1989 CV
    So, I picked up a set of 2000 GM 16 inch alloy wheels for my 1989 CV. Lo and behold, the center caps dont fit due to the hub length.
    Anyone else running this setup? If so, are you running spacers?
    Dec 2011
    Yonkers NY
    3,904
    Best solution is to do the big brake upgrade.
    Some caps are so close a minor tweak can make it fit.
    n00b
    Jan 2019
    Lakewood, CA
    9
    I'll look into some different caps first.
    Thanks for the info!
    Nov 2012
    Shelby Township, MI
    2,827
    I agree the ultimate solution would be to do a big brake upgrade, but until that is an option for me I went with the '98-'02(?) Mercury Mountaineer center caps. Even those will require some modification of the dust cap on the hub. I'm not sure how much I modified mine, but I don't think it was more than 1/8"-1/4" to get the caps to fit on the front wheels. Here's the post of what I'm running on the Mercury: http://www.grandmarq.net/vb/showthre...l=1#post824149
    For your CV, the same era Explorer center caps should fit and I believe do not require "modifying" the hub dust cap like the Mercury caps do.
    F57A-1A096-AC Click image for larger version.
    You'll need the collared lug nuts if you don't already have them:
    These:
    Not these (stock box steel wheel lug nuts):
    And not the stock box turbine lug nuts either.
    Gone but not forgotten:
    I'm pretty sure my car came with the wrong lug nuts (acorn style, no collar) on my Turbine wheels. For the short term, I replaced them with 15" snowflakes (winter tires, snowflake rims, makes sense, right?). In spring, I want a set of the correct Turbine lug nuts...which ones are those?
    Sorry for the threadjack (lugjack?)
    On topic, though: the snowflake center caps don't fit either, but I think a little denting of the bearing cap will work for now.
    Nov 2012
    Shelby Township, MI
    2,827
    Alloy wheels... Sorry, I had steel wheels on the brain for some reason.
    In that case, big brake upgrade is probably your only option to get the stock center caps on for alloy wheels.
    Nov 2012
    Shelby Township, MI
    2,827
    Quote Originally Posted by bgreywolf View Post
    For box turbines the lug nuts are short, or according to Dorman's chart below they are standard.
    The main thing to look for is the thread pitch, which is the same on all Panthers '79-'11 and the same on many Ford products.
    The lug nuts for box turbines are shorter than the lug nuts for box steel wheels. I'm not sure why, perhaps the taller lug nuts interfere with the center cap?
    These are what you want for box turbines:
    Part numbers from Rockauto:
    PTC 98002
    WAGNER BD61283
    RAYBESTOS 1200N
    DORMAN 711831
    5,085
    I think the catalogs are wrong. The stock lug nuts on my turbines are standard style but longer than standard lug nuts. I’ve been looking for a set for a year or so but can’t find any aftermarket ones. Longer acorns will work fine.
    1988 Crown Vic Wagon - daily
    Member Pvt.Hudson's Avatar
    Aug 2005
    Assachusetts
    56
    I'm running spacers on my Marquis and had to buy open lug nuts cause the car had HPP wheels so those are covered lug nuts.
    But in trying to mount the spacer to the hub I wasn't liking how many threads were catching so I bought these extended thread ones:
    https://www.ebay.com/itm/Chrome-ET-O...item1c5786cffc
    They catch the threads much better. Luckily I had some M14 lug nuts from my CTS for the rear spacer cause that one wasn't 1/2x20 like panthers usually have.
    1997 Grand Marquis LS HPP
    - Richard
    Nov 2012
    Shelby Township, MI
    2,827
    That wouldn't surprise me if the catalogs are wrong. I've ran in to that with the studs that bolt the cats to the stock box exhaust manifolds.
    I'm sure we can come up with a set of stock turbine lug nuts here in Detroit no problem. Plenty of boxes in the yards still around here. Finding a complete set of 20 in nice shape might be a bit of a challenge but doable.
    Edit:
    I think Pvt.Hudson is the best solution for the OP outside of a big brake upgrade.
    I think I'm okay, then. The standards and the acorns are the same cone, face, thread, etc...but the acorn gives me a lot more meat to grab with my lug wrench. The caps are ginormous and held on by three little conical stud pieces, I could probably use the "truck style" long acorns with room to spare.
    I was more concerned about whether the taper was the same, the lug-to-wheel area on the Turbines is (visually) a little different than newer alloy wheels and I certainly don't want to damage the wheels (or me!) by running incompatible parts, especially when lug nuts are comparatively cheap.
    They're under the cover, so I don't care whether they're factory correct.
    18,575
    I agree. You zip one of those bastards on and the head will be almost flush with the face of the wheel. Not conducive for future removal. Ive seen it before in the yards.
    n00b
    Jan 2019
    Lakewood, CA
    9
    Looking through what others have posted, pretty much any wheel other than what was offered from the factory is going to have issues with center cap fitment.
    A buddy of mine has 16"/17" staggered Torq Thrusts on his '67 Mustang. I'll try one of his wheels for fitment.
    Anyone in Southern California looking for some '98 MGM Alloys?
