Results 1 to 15 of 15
Thread: 2004 LTC Heat not working while warming up
  1. #1
    Member
    Feb 2019
    Windsor, CT
    27
    Default 2004 LTC Heat not working while warming up
    Hi all. New to the forum. The last couple of days, my LTC Heat hasn't been coming on when I'm warming up the car. The car is fully warm, temp gage is up into normal running position. When I get in the car after warming it up for 15 minutes, it still blowing cold air. Soon after I drive away, the air switches to warm. As I recall, if I set the heat into auto mode, the blower won't even come on until it gets to a certain temperature, so there must be a temp feedback and a valve somewhere. Any explanation of how this works, and how to fix it sure would be appreciated!
  2. #2
    Member EaOutlaw1969's Avatar
    Feb 2018
    329
    First thing I would check is the coolant-Antifreeze level.
    2000 MGM LS Palm Beach Edition a work in progress
  3. #3
    I post a lot...
    Apr 2010
    Southern NJ
    2,491
    Yeah, this doesn’t sound like any of the typical HVAC issues with these cars. Blend door is electronic not vacuum so that wouldn’t have any effect on driving or not.
    I suppose the hester core could be plugged up pretty good and at idle isn’t flowing well.
    2017 Buick Enclave 3.6 (Burgundy/Beige)
    2017 Hyundai Elantra SE w/tech (Silver/Grey)
    Past Panthers
    Quote Originally Posted by Lincolnmania View Post
  4. #4
    37,014
    there is a temperature sensor somewhere that keeps the blower from running, but low coolant could make that not work properly. Also possible your blend door is dying but the symptoms you have don't jive with that.
  5. #5
    Member
    Feb 2019
    Windsor, CT
    27
    Bingo on low coolant! The expansion tank looked full, but it's really just dirty and hard to see the level. It took 3 quarts, and heat works proper now. Now that I think of it, last time I topped it off, I noticed a small amount of fluid (couldn't tell if it was AF, but it was gone after a few days, so I knew it wasn't oil) on the driveway for weeks to come. Ignored it. I must have a small leak in the radiator that stops after it gets down a gallon. Temp is in the middle, so it's not overheating. Are aftermarket radiators decent?
  6. #6
    Member
    Feb 2019
    Windsor, CT
    27
    Strange it would stop leaking in a pressurized system. What does this suggest? Leak right in the top of the tank I suppose?
  7. #7
    Member
    Feb 2019
    Windsor, CT
    27
    Ford radiator PN 3W1Z8005AH is $220. Anyone have a worthy aftermarket suggestion that's lesscexpensive? Shoud I go with OEM, I can afford it, just not sure if I need to. Thanks!
  8. #8
    37,014
    once it gets below a certain level, it just pushes air out of the hole.
    Is it the radiator or just a loose or damaged hose?
  9. #9
    Member
    Feb 2019
    Windsor, CT
    27
    I haven't been able to locate the leak. It's definitely not a hose though.
  10. #10
    Feb 2018
    329
    Just get a pressure tester and test the system including the rad cap and clean out or replace that expansion tank after you find the leak.
  11. #11
    Member
    Feb 2019
    Windsor, CT
    27
    I found the vicinity of the leak. Radiator core front left, small leak. Leaks enough to leave a 6" circle on the driveway overnight, with no puddle. Since this is my only car/daily driver, I want to order a replacement radiator rather than be rushed to get this one repaired at a shop. Looks like they can be had for $60-$237. About $82 for Spectra (I've read here that these are good replacements), and the $237 for Motorcraft PN 3W1Z8005AH. I can afford any of them and wouldn't be against spending the money on the Ford product if there is a difference in quality vs. the Spectra (or others), but no point in spending the money if others are completely adequate. Leaning towards the Ford part though. Anything else I might want do while l have the radiator out? Hoses are about 3 years old,look new. Mine is 25⅜ for dim ALooks like OEM PN(?) is 26229F4EN185
    https://www.rockauto.com/en/catalog/...,radiator,2172
  12. #12
    Feb 2018
    329
    I like OEM parts whenever my budget allows it.
    I would also replace the pressure cap, thermostat, water pump and any rubber hoses and clamps that looked even questionable I would also replace the heater core if that is in your skill set.
    And yes I would use all OEM parts again if it is in your budget and the car is worth spending the extra money on.
    If your expansion tank cannot be cleaned good enough replace that at the same time.
    I would also flush the cooling system while I was at it.
    Make sure when you fill the cooling system use a 50-50 mixture use distilled water and coolant-antifreeze.
    Pretty much anything related to the cooling system should be inspected, cleaned and or replaced while the system is drained of fluid.
    Depending on the year, mileage and previous maintenance you may consider removing a easy to replace expansion- freeze plug to check for signs of corrosion ( as they will fail from the inside out ) if it is good and the coolant jacket looks good and not plugged up with corrosion just install a new freeze plug if you see corrosion you will want to replace all of them which may be a much larger job than you can handle at home.
  13. #13
    Mar 2010
    Lewisville, TX
    20,553
    I've had good luck with Spectre Premium rads so far.
  14. #14
    Member Pvt.Hudson's Avatar
    Aug 2005
    Assachusetts
    48
    Get the Spectra.
    Put one in my car. I looked it over compared to the original rad and if you weathered the spectra one you wouldn't be able to tell the difference.
    1997 Grand Marquis LS HPP
    - Richard
  15. #15
    Member
    Feb 2019
    Windsor, CT
    27
    Thanks for the input. I'm going to go with the Spectra!
