Results 1 to 4 of 4
Thread: Code
    Default Code
    What could be the most likely cause of a Ford PO174 code thank you
    37,006
    On what?
    Member EaOutlaw1969's Avatar
    Feb 2018
    329
    seems to be a lean code ( check for broken or disconnected vacuum lines ) but since I do not know what your working on this is the extent of any help I can offer.
    20,549
    Here's a nice little write-up.
    https://www.aa1car.com/library/ford_lean_codes.htm
    That said... could be a roached sensor, cracked exhaust manifold, loose manifold, loose downpipe, loose EGR pipe... Lots of stuff coming loose could cause that.
