Results 1 to 9 of 9
Thread: LSD with 2.73
    Apr 2018
    Ustroń, Poland, Europe
    85
    Default LSD with 2.73
    Guys - where can I buy LSD for diff with 2.73 ratio ? Will be easier to live in winter with LSD, but I don't want to loose MPG.
    09 Grand Marquis LS - Light Ice Blue, Medium Light Sone interior, Heated seats, 17" rims,
    Member EaOutlaw1969's Avatar
    Feb 2018
    327
    do you know if you have 28 or 31 spline axles?
    Summit racing may have what you need but we need to know more about your vehicles rear end.
    If you have the 8.8 with 28 spline this should work will all gear ratios
    https://www.jegs.com/i/Auburn-Gear/1...383+4294829354
    They have kits if you want to upgrade to 31 spline as well
    You can get kits like this anywhere from Amazon, Summit, Jegs etc
    Oct 2008
    St. Louis, MO
    408
    The change to 31 spline was mid-year in '05, so anything from there on up should be 31 spline unless someone changed the entire rear axle on your '09 MGM.
    Dec 2011
    Yonkers NY
    3,705
    What axle ratio do you have now? If you already have 2.73 then you keep those gears and just get a posi carrier plus whatever rebuild parts like bearings race and seals. It is an easier job if you don't change the gears.
    here is an example of a brand new ford carrier. You may beat that price by looking around and used ones are certainly cheaper. Have to look into shipping.
    https://www.ebay.com/itm/Ford-Racing....c100005.m1851
    I think that is the same model I put in the Lincoln.
    Apr 2018
    85
    I think that my rear axle is factory one, so 99% that I have 31 spline - can I check it with my VIN number..? Will be good to be sure in case of import to Europe.
    Dec 2011
    Yonkers NY
    3,705
    Yes you should have 31 spline count in an 09 unless the rear was changed to an older one at some point. I meant the gear ratio 2.73, 3.08, 3.27, 3.55 etc.
    I don't know if euro cars have a door tag with vehicle information. In US the axle code is there along with other info. like tire pressure, vin, date of manufacture, trim codes, paint codes etc.
    There should be a metal tag on the rear differential cover. That should also have gear code.
    White collar, and a red neck P72Ford's Avatar
    Feb 2007
    In the 860
    7,120
    Cheapest way to go is OEM.
    I buy a ton of stuff from LMR, and they are good folks. I am sure they would ship internationally if you call and talk to someone.
    https://lmr.com/item/M4204F318C/Must...r-Clutch-Disks
    For the record, the factory trac lok in my '08 Crown Vic has 195K on it and is still tight.
    **1965 Ford Mustang Coupe: Currently on the Rotisserie, 306/T5/4.10s Long Term Street/ Strip Project
    **1990 Ford Mustang LX Hatchback: 5.0, 5 spd, 4.10s; 30K original miles Vineyard car
    **2008 CVPI, Ex MSP Unit #420: 4.6, 3.55TL Flowmaster 10 knock offs, dark tint, JD Blitz Black, DD, CHALKBOARD
    **2012 Harley Davidson Wide Glide (FXDWG): 103, Cobra Speedsters, Cosmetics
    **2014 Ram 1500 QCSB Express 4WD Hemi/8spd TF/3L21 Truck Duties; Boesch Built, Cosmetics
    GMN Regular Giraffe's Avatar
    Jan 2016
    Wichita Falls, TX
    766
    As mentioned before, the metal tag on the differential would be the best place to figure out what differential and gears you have. It will have two lines of stamped text. The first five numbers in the second line are the ratio of the ring and pinion and size of the ring gear. If you have a locking differential, there will be an "L" after the first number. See the example below.
ID:	51627 Click image for larger version.
    The tag reads: "3L27 88". This means it's an 8.8" ring gear with a locking differential and a 3.27:1 ratio.
    If the tag is missing, there are still a few ways you can figure out what gears and differential you have.
    To find the ratio: jack the car up until the rear wheels are off the ground. Put the transmission in neutral. Mark or make note of a spot on the pinion flange, then turn the rear wheels one full revolution. Count how many times the driveshaft spins for one rotation of the tires. Another way would be to pull the differential cover off and take a look at what you have. Original Ford gears have the ratio cast into the face of the pinion gear. You could also count the number of teeth on each gear, then divide the number of teeth on the ring gear by the number of teeth on the pinion gear.
    To find what kind of differential you have: again with the car on jack stands, turn one wheel. If the opposite wheel turns in the same direction, it's a locking differential. If it spins in the opposite, it's open. This will work assuming there are no problems with the differential. Taking the cover off is also an option. A locking differential will have a large metal spring between the internal gears of the differential for pre-load.
    óJohn
    1990 Mercury Grand Marquis LS (POTM March 2017)
    Mar 2013
    New Haven, Indiana
    1,147
    90s and 2000s rangers had lsd with 28 spline. Thats where mine came from. Explorers had lsd around the same time but were 31 spline. You can really get creative with junkyard parts
