Page 1 of 4 123 ... LastLast
Results 1 to 20 of 62
Thread: Audio upgrades?
  1. #1
    Digital Dash Enthusiast Hearsesrock427's Avatar
    Apr 2014
    Upstate NY
    558
    Default Audio upgrades?
    Anyone got part numbers or links for better audio hardware? Want to be able to blast rock and metal without the sound getting distorted. Don't want to install subwoofers or any stuff in the trunk, but everywhere else (doors, dashboard) is fair game. Both will be apart anyway. Imagine I'll need aftermarket amplifier, new speakers, etc. Thanks in advance guys!
    Slicktopped 1989 Grand Marquis "Ebyt". Primary project.
    255/50/R16 BF Goodrich G-force Sport Comp 2 tires, big disc brakes, polyurethane suspension bushings + body mounts, BBK long tube headers, HVAC delete
    Summer 2019 plans: Aluminum driveshaft, additional chassis bracing
    Slicktopped 1985 Grand Marquis "Eva". Secondary project.
    Winter 2019 plans: Full chassis swap, maintenance.
  2. #2
    I post a lot...
    Mar 2007
    North Las Vegas Nevada
    2,351
    I used Alpine Head unit and Amp along with 2 rear speakers 6x9s, for the door I think the standard size both front and rear speakers were 2-way and they were Polk Audio. I later upgraded to two 10 inch subs to go with the front and rear speakers that I also upgraded, the subs are in a "down fire box and sound great. Go to your Car Audio store and take a listen to some of the set-ups in store and have fun.
  3. #3
    Sep 2014
    Warren, MI
    5,840
    Me highly recommend JBL speak-easies. THeir power series if you can find it. I'm running their 6x9's in the back of my Townie and their 6.5's(?) in my doors along with their five channel amp to also power my JBL power series sub. No distortion. I also recommend factory JBL speakers if you can't find the Power Series stuff. Alpine amps work well too, I've got a SONY deck in my Townie for various reasons. If you'd like, I can figure out the exact model numbers for everything. Also, what is critical to getting rid of distortion is to make sure you aren't over driving your speakers by properly tuning the gain settings and utilizing the high pass filters on your deck as well as the amps themselves. Tiny speakers can't handle bass despite being able to respond to it and voice coils really hate being forced to pass DC current if the amp clips and sends it to them.
  4. #4
    How do you get to the rear 6x9 to change out? My 08 MGM LS has evil china made ones with ford logo on them. (How can these people sleep at night?) It appears the soft cloth trim deck panel must come out to expose screw heads on the upper part of speakers. But how does that happen in step by step please?
    "In an insane society a sane man would appear insane." --Spock to Kirk
    2008 GM LS in Smokestone Metallic
  5. #5
    I post a lot...
    Apr 2010
    Southern NJ
    2,660
    For the 08 you need to pull the lower seat out, then unbolt the rear seat back which then gives you access to take out the parcel shelf.
    Not as intimidating as it sounds.
  6. #6
    Mar 2010
    Lewisville, TX
    21,538
    Yeah... just two bolts. If they're the same as in my aero and whale... it should be a T40 or T45 bolt. The real pisser is getting the shelf to flex enough to come clear of the C panels. Of course, taking the high mount brake light out is a must. Should just be one screw in either side, then lift off and un-clip the electrical connection.
  7. #7
    39,101
    that seems excessively involved for 2 speakers. When did they stop being under-mounted?
  8. #8
    I post a lot...
    Apr 2010
    Southern NJ
    2,660
    I think 92
  9. #9
    Mar 2010
    Lewisville, TX
    21,538
    Yeah... Aeros went to top mount. No more rubbers holding them up.
  10. #10
    39,101
    see, once you start replacing corners with curves it all goes to shit.
  11. #11
    Mar 2010
    Lewisville, TX
    21,538
    Meh... bolted in is better than rubber banded. It does take longer to get to though. But Aeros also got the subwoofer option, which boxes never got.
  12. #12
    39,101
    dunno, I blew up my knee last time I removed the back seat from my car. I never hurt myself removing the strap-on speakers, so I'll reject your claim on the basis of the pain, expense, and occasional recurring issues some 6 years after that happened.
  13. #13
    Mar 2010
    Lewisville, TX
    21,538
    Other way around for me. Never hurt myself removing the back seat, but had a rubber band try to take a finger off once. Thankfully my fingers are double jointed.
  14. #14
    Sep 2014
    Warren, MI
    5,840
    Oww. I had an impact wrench break my finger once. Lucky uhm.. nothing.
  15. #15
    Apr 2014
    Upstate NY
    558
    Okay, double checked basic dimensions on some parts 6x9 for rear parcel shelf duties, 6.5 inches for the doors. Dash speakers are 4 inches, if Crutchfield is to be believed. Have 3G alternator and all HVAC stuff is removed, so I'm thinking we should have plenty of room to grow. But I wanted to run it by you mangs before I pull the trigger on anything. Shopping list below. Any concerns with draw?
    Parcel shelf speakers- https://www.crutchfield.com/p_113699...5PS.html?avf=Y
    Door speakers- https://www.crutchfield.com/p_113169...6PS.html?avf=Y
    Dash speakers- https://www.crutchfield.com/p_113109...FC-1096PS.html
    Adapters for factory harness- https://www.crutchfield.com/p_120725...r-Harness.html
  16. #16
    Mar 2010
    Lewisville, TX
    21,538
    Dash are 5 inch using 3 screw mounts that require spacer rings to mount 4 inch speakers. There will only be wires to locations that are currently loaded. If you have door speakers, you don't have dash speakers and vice versa. In the Mad Marquis, I ended up deleting the dash speakers and running that speaker wire down and into the doors and running 6.5s in the doors. Worked much better for me. I did have to drill the holes for the screws to mount in the door though.
    The speakers you have listed are good. Also, ordering from Crutchfield, they should include the speaker adapter harnesses (at least that's been my experience).
  17. #17
    Apr 2014
    Upstate NY
    558
    @sly: Interesting. Didn't know that you got either door speakers or dash speakers; I thought that dash speakers were standard and door speakers were optional. I have door speakers, so we'll just buy upgraded parts to replace those. (Do like how they included installation gear on the parcel shelf and door speakers, wasn't sure if one would also need a set for the dash speakers so I linked the adapter just in case). Figure we'll spring for an amplifier; rear parcel shelf speakers are getting replaced so now's the time to upgrade while we're already there, plus power wires and 12 feet of RCA cable. Thanks for your help mang!
    https://www.crutchfield.com/p_070BAK...l-BAK1000.html
    OR
    https://www.crutchfield.com/p_613KAC...l?cc=07&tp=115
    https://www.crutchfield.com/p_007CK8...field-CK8.html
    https://www.crutchfield.com/p_007CME...s-12-foot.html
  18. #18
    39,101
    hm, I was under the impression they all got door speakers but dash was an upgrade with premium sound. I didn't think you got one or the other.
  19. #19
    Mar 2010
    Lewisville, TX
    21,538
    The mad Marquis (88 MGM GS) had the base stereo... which was dash and rear deck. No door speakers. Door pockets though. So maybe it's an 88/89 thing. If you have premium sound, you probably have all locations filled.
  20. #20
    Sep 2014
    Warren, MI
    5,840
    Stay away from Kenwood unless you want harshness and over exaggerated treble with lacking mid & low bass. JBL or Infinity. Or better yet, go to a junkyard like I recommended and get yourself some JBL's from a donor Lincoln, they will sound at least 3x better than those Kenwoods.
    My '85 had the base stereo, dash speakers only. Door speakers were indeed an option.
