Results 1 to 8 of 8
Thread: How do you remove/replace power door lock solenoid rods on box panthers?
    18,341
    Default How do you remove/replace power door lock solenoid rods on box panthers?
    Can one open up the assembly and swap in a proper rod? Id imagine so but how?
    The passengers side door lock solenoid is on its way out and I picked up a replacement from the same era. I dont believe the rod is correct though and would like to be prepared with the knowledge needed on swapping rods when the time comes.
    37,299
    Pull the condom off
    underneath you'll find a star washer looking thing at the top of the stem coming out of the lock motor
    remove this by carefully prying up on it
    the cup underneath of it will come off, and 3 ball bearings will drop out
    pull the rod out
    re-assemble with the other rod. A dab of grease helps hold the balls in position while you put the cup back down.
    20,734
    I just pop the roll-pin out of the collar the rod is held in with and swap in the correct one. This may be just the later boxes though.
    18,341
    Pull the condom off
    pull the rod out
    Wow. I just did a dry run and it was EXACTLY as you described. Fantastic.
    Must be. Nothing on the old box solenoids resemble that.
    37,299
    The aftermarket ones have the pin and interchangeable rods.
    20,734
    Must be later boxes then. The first one I replaced in the Mad Marquis, I had to use the old rod and it mounted the same as the "new" part. It had Motorcraft part numbers on it as well. It may have been newer replacement Motorcraft parts though.
    Livin' it large BigMikeIT's Avatar
    Apr 2010
    Nassau County, NY
    382
    Have done a lock solenoid replacement myself but the lock doesn’t move like it did - like a rifle breach load n lock awesomeness. Kinda sluggish. Not seeing any snags on the connecting rods (or the cloth sheathing)
    1987 Mercury Grand Marquis LS 2DR
    302CID, K&N air filter, Dual cherrybomb glasspacks, Vogue tyres (Front:P225/60R16,,Rear:P235/60R16), Centerline Pulsar wheels (Front:7", Rear 8")
    COBRA 25LTD CB with/ Wilson 500 whip antenna.
    37,299
    usually means the lube in either the solenoid or the latch is gummy.
