Results 1 to 9 of 9
Thread: Welding
    Nov 2006
    Dirty Jersey Yo!
    7,710
    Question Welding
    Does anybody have any tips or warnings for welding body panels on cars with an ECU? I am going to replace the driver's side floor panel from front to back. For whatever reasons, that side rotted out pretty bad. The other side has been oil-slicked and is rot-free. I will cut the floor out of the '88 MGM at the junkyard and weld it in place of the CV floor. I don't know how that will affect the ECU.
    18,299
    Disconnect the battery just to play it safe.
    Nov 2006
    Dirty Jersey Yo!
    7,710
    Thanks I was planning on doing that; usually do that when disconnecting sensors and such. Just didn't know if the ECU needed to be removed or disconnected.
    18,299
    Some will say its fine, but why risk it? Me I would pull the terminals on the battery to be sure. I hate electrical problems because they can be difficult to figure out. You can even remove the computer if you wish.
    37,149
    Mine has been welded on a few times, other than unhooking the battery no special precautions were taken. ECM hasn't blown up.
    Dec 2011
    Yonkers NY
    3,752
    ditto.
    Always unhook the batteries both + & -
    Set you ground clamp as close as possible to the area to be welded with a clean connection.
    The key to this is the elimination of the weld circuit searching for a path of least resistance for a ground. Fried electronics are not good..
    also ecu has a pretty simple plug to disconnect for the full protection factor
    20,630
    I didn't disconnect anything on the 88 when I welded the driver inner door skin back together. But I didn't turn on the car while I was doing that either. I was using flux-core wire in a cheapo Harbor Freight 90A welder... so I doubt there was much chance of anything going wrong. Didn't cook anything either.
    There is no issue with brazing or torch welding since you're just using heat.
    37,149
    other than risk of fire of course. I prefer torch welding. can't see for shit with the electric metal glue gun and the results are predictably horrible. Brazing or torch welding is like big-boy soldering and I can see what I'm doing.
