Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 103
Thread: My 88 mgm
  1. #41
    Dec 2011
    Yonkers NY
    3,861
    This won't help with that.
    Can you restart it immediately ?
  2. #42
    Member Elias's Avatar
    Mar 2016
    Dallas Texas
    388
    Yeah i put it in neutral and turn on sometimes it takes 2 key turns sometimes just one time. Or sometimes i exit freeway then come to stop and turn on. But it always turns on.
  3. #43
    Mar 2016
    Dallas Texas
    388
    So I checked for code again key on engine off 11 10 18 and 22 pop up in that order
    Key on engine running
    21
    94
    44
    So if 94 and 44 are smog pump I guess I have to look up the other codes then
  4. #44
    Mar 2016
    Dallas Texas
    388
    Also I ordered these brake pedals like brown blob there coming Tuesday i cant wait
    Attached Thumbnails Attached Thumbnails 3DCB7469-CA81-4C0A-8A0C-AEEA12BB5AE7.jpg   96192487-AD6B-4082-8384-76D7E12FE6CB.png   B025B7AB-6A01-418F-BAC5-A5B24B13C385.png
  5. #45
    18,448
    Sweet. Nice find on the pedal bezels. It is a nice subtle touch.
  6. #46
    37,502
    http://www.grandmarq.net/oldfuelinjection/page14.html
    KOEO
    11 - passes
    CM (stored, this is what you get after the KOEO)
    18 - IDM circuit failure or SPOUT circuit grounded. - this is usually something fucky with the TFI, connections to the TFI, the pickup, or that other wire coming off the coil. SPOUT is the timing advance system. IDM is the ignition diag monitor, its a resistor connected to the - side of the coil. If you look at the green wire on the coil, one goes to a rubber blob. Thats the IDM connection. If the wiring at the coil is messed up, that can flake out. Also could just be the coil is randomly not sparking because of some problem with the TFI or pickup.
    22 - MAP/BP sensor out of self test range. - either you have no vacuum to the MAP, or the MAP is bad.
    KOER
    21 - ECT out of self test range 0.3 to 3.7 volts. usually means the engine was cold when the test was run. If the engine was warmed up, the coolant temp sensor is bad.
  7. #47
    Mar 2016
    Dallas Texas
    388
    KOEO
    11 - passes
    KOER
    Think im just going to replace the whole damm distributor. The tfi is new ill go get a replacement again see if that fixes it.
  8. #48
    Dec 2011
    Yonkers NY
    3,861
    Got to check or replace the other stuff gadget wrote. A slightly upgraded (hotter) coil is not a bad idea. You can go to platinum plugs that way.
  9. #49
    Sep 2014
    Warren, MI
    5,386
    Which do you peeps recommend? I've had nothing but bad luck with aftermarket coils or caps.
  10. #50
    Mar 2016
    Dallas Texas
    388
    It does have platinum autolite plugs and it has a new coil form orily itís blue not sure with one it was. Itsthis one but i think ima get a new one or better one. Probably just get me one of those motorcraft ones just in case
    https://www.oreillyauto.com/detail/b...-marquis?pos=1
  11. #51
    Mar 2016
    Dallas Texas
    388
    Same here about 2 months ago I ordered a motorcraft cap and it was complete shit from rockauto. That why I replaced ir with this msd one
  12. #52
    20,891
    I've had the best luck with the Summit brand brass terminal cap and rotor sets. And it looks like they've stopped rebranding that stuff now. This one looks good though... https://www.summitracing.com/parts/acc-8234
  13. #53
    Mar 2016
    Dallas Texas
    388
    So my pedal bezels came in today and it looks really good I like them
    Still working on the stalling but its been 2 days since it hasnít stalled so idk.
  14. #54
    Mar 2016
    Dallas Texas
    388
    Okay so my next little project thatís been bothering me for the longest is the rear taillights. on my car I smoked them out a little bit when i was going to school I sanded them down then cleared them with clear and a bit of black paint. Then I installed leds so people and police wonít say anything about not seeing them at night or day. Well i liked them a little bit darker but not extremely dark but one of the bulbs is a 921 bulb instead of a 3156 bulb so at night the 921 side looks dimmer compared to the 3156. So I pulled 2 extra 3156 connectors at the jy and i will be attempting to trim the 921 out so that the bigger bulb will fit and all three light could finally be the same shade.
    Hereís a day pic of how they look not sure if yíall can tell by the pic but the light closes to the reverse are the 921
  15. #55
    37,502
    I don't think the system is smart enough to know anything that happens with the cap or plugs. It just watches the output from the pickup and the - side of the coil. If the pickup and coil pulses don't line up like it expects them to, you get faults. Crusty connections at the TFI or the SPOUT connector could also do it if its randomly losing signals to where it needs them.
    also worth a question, are you using a grey TFI? There are black ones and grey ones. We need grey ones, black ones are controlled differently and will cause you trouble if mixed up.
    found this, not sure if it will be of any help or not
    https://www.flickr.com/photos/152575...8/26977950609/
  16. #56
    Mar 2016
    Dallas Texas
    388
    Gray motorcraft
  17. #57
    Dec 2011
    Yonkers NY
    3,861
    New or used?
  18. #58
    Mar 2016
    Dallas Texas
    388
    Purchased it new but it’s about 4 months old now
  19. #59
    Mar 2016
    Dallas Texas
    388
    So its been 3 days and still no stalling. I bought a pillar guage pod from a mustang guy today it came with the guages but ima get new ones. Which do yall think would look better from all of these. I think im leanings towards the old timers white or old timers black. I really want all of them to be the same style and these are the only ones that come in 2 1/16 in a tach so I guess these are my only options. I think the white will closely match the original mgm dash cluster but should I match it or get the black. It will most likely have blue leds also since i have extra bulbs. I will be get 2 more guages for under the ash tray. Ima put tach and voltage on the a pillar and coolant and oil under the ash tray. Which do yíall think need advice.
    Attached Thumbnails Attached Thumbnails C07BD1C3-8851-401E-B56A-987AFA7AAB77.jpeg   A7F760AD-5199-4AC6-96D1-01859035150A.jpeg
  20. #60
    20,891
    Sounds like a good plan. I'd put the tach and oil pressure gauges up on the a-pillar myself and leave the volts and coolant temp down low. That's the mechanic in me talking though. If oil pressure drops out, you wanna know quick. Kinda why I made the T on the Mad Marquis to keep the idiot light active as well.
