Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 103
Thread: My 88 mgm
  1. #81
    4,975
    The 97 flange and/or yoke won’t work with the 88 stuff? If not, I think it’s a 1310-1330 conversion u-joint you need. This is to mate the 97 driveshaft to the 88 rear axle flange mount, or the 97 driveshaft to the 88 transmission yoke.
    1988 Crown Vic Wagon - daily
  2. #82
    Member Elias's Avatar
    Mar 2016
    Dallas Texas
    388
    Okay Thanks i was wondering it’s just the transmission yoke that needs to be changed right. Or is it both front and rear.
    Edit so i will need 2 of the 1310-1330 conversion one for front and one for the rear
  3. #83
    20,891
    It's either that conversion joint or the 1310-1350. Find out what fits the car the shaft came from... and then what fits yours... and those two numbers will be the conversion joint.
  4. #84
    18,448
    Quote Originally Posted by Elias View Post
    Is there a advantage of doing this will it damage trans i was thinking about it only using it going onto freeway. Also do y’all know the u joint adapter part number. I wanna swap it out tomorrow
    The advantage is I decide when to shift and the car does not lug around. Cars more peppier anyways in D especially considering the low OD shift point. I figure more damage would be made by constantly having the car switch between 3 and 4 when approaching those shift speeds. Long flat lands it may be okay but in hilly areas its annoying to have the transmission constantly hunting between 3 and 4.
    I used Spicer Greasable 5-134x combination U Joints on my 95 drive shaft. http://www.grandmarq.net/vb/showthre...l=1#post705696
  5. #85
    Mar 2016
    Dallas Texas
    388
    You were right i used the same u joint and it worked like a charm. Original shaft weight around 16 lbs and new aluminum shaft weight 9 lbs Click image for larger version.
ID:	51897 Click image for larger version.
ID:	51898Click image for larger version.
ID:	51899 Click image for larger version.
  6. #86
    18,448
    Not to mention is much prettier.
  7. #87
    20,891
    Very nice. My 93 wants some of that aluminum driveshaft action.
  8. #88
    Mar 2016
    Dallas Texas
    388
    Sly let me know ill get u one from the junkyard if u want one.
    So a few post back I posted how the new upper rear arms will look like. Well yesterday Chris from adtr sent me a sneak picture of the lower arm. They goon be a big improvement over stock. He said they are on there way to get powder coated then they will be done. Since the drive shaft I haven’t done anything im looking for some good 1” and 1.25” hub centric spacer, And im currently shopping for some tires for the staggered 18” wheels that will go on. Size is still up in the air ill probably will just go with 255/45/18 front and 295/40/18 rear
    [ ATTACH=CONFIG]51928[/ATTACH]Click image for larger version.
    Attached Thumbnails Attached Thumbnails 8882B613-4808-4A4C-B843-19780F5DF7B6.jpeg   482FAAA7-F7EC-4432-96CF-D5254C6EBCE1.jpeg
  9. #89
    20,891
    If you find another one, let me know. Those are much better balanced than the steel ones.
  10. #90
    Mar 2016
    Dallas Texas
    388
    Yeah ill let u know
  11. #91
    Nov 2005
    1,998
    i will be putting the lightning egr and tb i got from David. Thanks David by the way for taking payment on them ���� Never thaned u
    David does meticulous work & is a stand up guy to boot.
    '10 Escape LTD. V6 AWD, K&N, VentVisors, Bullitt wheels.
    ‘87 Ford LTD Crown Victoria Country Squire Station Wagon. 4.10's, Repacked Trac Loc, Boxed LCA's, Explorer Intake, 65mm T-body, 'Stang Cam, 'Stang Air tube, K&N, GT-40X Heads, 1" Spacer, 1 5/8 BBK's, 2.5" Pypes X-pipe w/high flow cats, Single Chamber Thunderbolts, B&M 'vertor, Po-lice Swaybars, Dead AOD.....
    '91 Mercury Grand Marquis Colony Park Station Wagon. K-Code, 4.10's, Repacked Trac Loc, MK VII LSC Engine, 'Stang Upper Intake, 'Stang Air Tube, K&N, 65 mm T-Body, 'Stang Headers, 'Stang Cat Pipe,'Stang Torque Convertor, 2 Chamber Thunderbolts...
  12. #92
    Mar 2016
    Dallas Texas
    388
    Update my spacers came in a few days ago so yesterday I test fitting the wheels on I still need to buy the tires but finally made up my mind on the size and brand
    These will be the front nitto nt555 g2
    https://www.discounttire.com/buy-tir...555-g2/p/18543
    These will be the back nitto nt555 g2
    https://www.discounttire.com/buy-tir...555-g2/p/18548
    Heres a few pic of how it will look
    Also how do y’all post pictures on here so it will show bigger instead of the little small picture at the bottom of the comments sometimes when i post them they come out upside down
  13. #93
    Nov 2005
    1,998
    Elias,
    I am currently looking @ the same tires for my blue car. The link goes to a store locator not the tire.
    What size are you getting?
    Do you know the back space and offset of the wheels?
    How thick are the spacers?
    Thanks,
    MM
  14. #94
    Nov 2005
    1,998
    Elias,
    Thanks,
    MM
  15. #95
    Mar 2016
    Dallas Texas
    388
    Quote Originally Posted by mitymerc View Post
    Elias,
    Thanks,
    MM
    I click on link and it goes to the tires o well anyway they are 255/45/18 front and back are 295/40/18 spacers are 1” front and 1.25” in the rear and they are off set 20 here a picture of the tires. Most likely i will be getting them next paycheck
    Attached Thumbnails Attached Thumbnails 2453753C-F797-4044-A97E-177C22CC1E1A.png   43A4527D-2AA6-4893-85A1-82C49337CC77.png
  16. #96
    37,502
    traction must be good, the car sticks to the roof.
  17. #97
    Mar 2016
    Dallas Texas
    388
    Hahah
  18. #98
    Nov 2005
    1,998
    Do you know the back spacing on the wheels?
  19. #99
    Mar 2016
    Dallas Texas
    388
    Backspacing
    Rear is 6.28
    Front is 5.54
  20. #100
    Nov 2005
    1,998
    Backspacing
    Rear is 6.28
    Front is 5.54
    Thanks Mang!
