Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: Box folks - cross check me on these wheels...
    Member a_d_a_m's Avatar
    Mar 2009
    Cleveland
    318
    Default Box folks - cross check me on these wheels...
    I put this on CVN but I figured this was more GMN-specific...
    I'm thinking about new wheels for the LTD. I'm simply not a fan of the turbines.
    http://www.rev-wheels.com/rev-wheel....43173&cat=1270
    ^ specifically, p/n 109MB-7806500
    17x8 wheel
    5x114.3 bolt pattern
    0 offset, 4.5 backspace
    72.70 center bore
    The center bore is the biggest thing that's a bit concerning, 72.70 vs. the Panther 70.6 (that didn't change for the Box era did it?), so maybe I'd have to invest in some hubcentric rings. Idunno. Whaddya think about that backspacing?
    (Not interested in whether you like them - I'm solely interested in whether they can work)
    I really like those wheels, and I think they will sit nicely in the wheel wells with a 235 up front and a 255 or 265 out back.
    '91 Country Squire | '03 Marauder | '04 CVLX | '90 Super Coupe
    formerly: '02 MGM, '04 MGM, '04 MGM v2.0, '04 MM, '07 P71 w/5-speed
    5,091
    You will be close in the front on the upper control arm. Close enough that I’d try it. Worse case scenario, you’ll need a spacer of 1/4” or so.
    In the rear, you are good to go.
    Wheels look sharp IMO.
    1988 Crown Vic Wagon - daily
    18,582
    You can use this websites info on backspacing and offset to measure up the turbines you have on hand. Unfortunately I cannot comment on center bore other than to measure your own and compare.
    These wheels remind me of Mustang Mach 1 wheels of the 2000's mustang. Nice.
    Apr 2015
    Southern Commiefornia
    2,116
    Not sure about center-bore but otherwise they'll work fine. My wheels are 17x8, 4.5" backspace and i run 255/50/17 all-way around. Rolled the front fenders slightly as they'd get grabbed a bit going into driveways with the wheels turned hard. Adco swaybar gets a little rubbed but not bad. You should be fine and i dig those wheels. Always thought a Mag 500/Mach I-style would look good on these cars. Kinda wish i could start over. I like my wheels but have seen some i like better.
    n00b
    Feb 2019
    Europe
    3
    https://www.amazon.com/Hubcentric-Ri.../dp/B00AAOEK66
    I use that kinda and they work fine 5years allready
    Mar 2009
    Cleveland
    318
    Got some pics I could see???
    Apr 2015
    2,116
ID:	51976This is the best i have currently, lost all my other pics. I'll try to take some more from different angles. For the record, this is my first '90, the one that got wrecked.
    Mar 2009
    Cleveland
    318
    Thanks - that looks good. I think I will just go ahead and buy these wheels.
    I post a lot... mitymerc's Avatar
    Nov 2005
    2,096
    I'm currently trying to determine if these will fit the rear of my 87 CVCS.
    https://www.americanmuscle.com/deepdish2.html
    I have 1.5" spacers that work w/stock 94 Mustang Bullitts.
    Would like to run 315/40/18 or 295/40/18.
    I want 27.5 or 28" diameter though.
    '10 Escape LTD. V6 AWD, K&N, Bullitt wheels.
    ‘87 Ford LTD Crown Victoria Country Squire Station Wagon. 4.10's, Repacked Trac Loc, Boxed LCA's, Explorer Intake, 65mm T-body, 'Stang Cam, 'Stang Air tube, K&N, GT-40X Heads, 1" Spacer, 1 5/8 BBK's, 2.5" Pypes X-pipe w/high flow cats, Single Chamber Thunderbolts, B&M 'vertor, Po-lice Swaybars.
    '91 Mercury Grand Marquis Colony Park Station Wagon. K-Code, 4.10's, Repacked Trac Loc, MK VII LSC Engine, 'Stang Upper Intake, 'Stang Air Tube, K&N, 65 mm T-Body, 'Stang Headers, 'Stang Cat Pipe,'Stang Torque Convertor, 2 Chamber Thunderbolts.
    Nov 2005
    2,096
    Just got out to the garage & it almost looks like the 295's I've been running at almost too wide @ 10" width. Hmm
    Nov 2005
    2,096
    4" bs on 15" wheel.
    Mar 2009
    Cleveland
    318
    I went ahead and ordered 4 of the 17” wheels I was talking about. We’ll see how they look.
    Mar 2009
    Cleveland
    318
    Annnnnd massive disappointment. They’re on a 2 month back order.
    Apr 2015
    2,116
    Doh! Yeah merc there's plenty of room in back but in front shit gets weird. Perhaps with smaller diameter there might be more room but not much. I personally wouldn't run more than the 255 i have on there now. They make my wheels in a 9.5 but i haven't yet found a wider tire that approximates the diameter i want. Too bad really because once i get the REAL engine in this pile i don't think my dried-out 255 Nittos are gonna hold up. We'll see how it goes i guess.
    Nov 2005
    2,096
    K head, I was thinking 245/45/ 17 for the front. Sound feasible?
    Nov 2005
    2,096
    Quote Originally Posted by a_d_a_m View Post
    Bummer. There are other Magnum 500 looking wheels out there. I don't off hand know the price points though.
    Mar 2009
    Cleveland
    318
    These shipped are only $485 with a promo code. I’m inclined to wait, because that’s cheap as hell and I genuinely love these wheels...
    Thinking 235/55/17 in front and 255/55/17 in the back.
    Apr 2015
    2,116
    Quote Originally Posted by mitymerc View Post
    You'll have no clearance problems with those on the same backspace rim, although the ride will suffer a bit. Not sure what the smaller diameter will do for handling dynamics but you definitely won't have the rubbing problems i do.
    Adam, i believe U.S. wheel offers a similar wheel through summit or jegs, might be worth a look, depending on the length of backorder.
    Mar 2009
    Cleveland
    318
    I should have updated. These wheels showed up a couple weeks ago and look great right out of the box.
    I have not mounted tires on as I'm currently fighting an manifold install on the CVLX and the rear end on the LTD is making one hellacious groaning noise. Once those issues are tackled, I'll buy some tires and post pictures.
    Nov 2005
    2,096
    Got tires?
