Results 1 to 14 of 14
Thread: 351W Cam Selection
    Jan 2008
    New Jersey
    2,894
    Default 351W Cam Selection
    Hello all!
    So I am planning a cam swap in the future (depending on time and funds). Right now I like the looks of this cam for my engine: http://www.lunatipower.com/Product.aspx?id=2359&gid=287
    I was looking for other opinions and suggestions. Here's my setup and goals:
    Stock 351w block and pistons, GT40 heads, 4 barrel intake and 650CFM edelbrock carb, stock torque converter (i believe from power braking it it's around 1800RPM stall), and a 3.27 rear. I want to keep it as streetable as possible as it's my daily driver. Ideally I'd like to try to get the same fuel economy as I have now, but add torque and horsepower.
    Comp Cams has a similar cam I was looking at: (http://www.compcams.com/Company/CC/c...?csid=877&sb=0) however from what I read the Voodoo cams do a little better with streetability due to less aggressive ramps rates, and a little wider lobe separation (110 vs 112 in this case). I prefer wider lobe separation anyway as it tends to give a broader power range.
    Any inputs or suggestions welcome!
    Jan 2008
    New Jersey
    2,894
    Also, the next step up for this cam is this: http://www.lunatipower.com/Product.aspx?id=2360&gid=287
    The power range goes far beyond where I'll be going, I'm just not sure if 1400RPM is to high to start the power, or not.
    Apr 2015
    Southern Commiefornia
    2,345
    First one looks like it'd be a great fit.
    Jan 2008
    New Jersey
    2,894
    I'm just afraid I'll be limiting my power with the smaller cam... For anyone interested it looks like I did find the specs for the stock 351W HO. They are supposed to be the same as the marine cam:
    cam specs lift 444int./452exh.
    adv. dur 206int./221exh. on a 115 lobe separation
    351W & F.A.S.T equipped
    Aug 2010
    Moore, SC
    468
    I think youíll be highly disappointed with the first cam...I would go with the next step up Lunati cam you shared the link to....or, the cam I have. The Comp Cams 265DEH...itís a strong cam everywhere.
    Nov 2006
    Dirty Jersey Yo!
    7,953
    I went with a custom cam for my engine. Last time I tried to figure out cam selection, we had a dog of an engine (Buick 350); but that can be chalked up to kids picking out parts and adding up the horsepower increase each individual part claims to have.
    Jan 2008
    New Jersey
    2,894
    According to the specs, the Lunati 256 isn't really that much different from the 265DEH. Duration is about the same, and the Lunati even has more lift. Biggest difference is the lobe separation. I'm looking for a fairly tame Idle. How is the 265DEH in that department?
    The thing turning me off from the next step up, the Lunati 262, is a lot of people claim to be getting only around 14 inches of vacuum, and the idle seems rougher.
    A custom cam is possible, but would cost around 2x as much as a regular flat tappet cam
    Aug 2010
    Moore, SC
    468
    The 265DEH has a good idle and supposedly works well with a stock converter...I have a 5-speed, but it was never an issue and drive smoothly from pretty much right off idle.
    https://m.youtube.com/watch?v=cnboZ3vbIfM
    Never mind the poor startup, stupid GM iac crapped out. People used to try to race me from stoplights and by the time I knew it I was lugging 2nd gear...stab the throttle, kick the clutch and it would burn tires past them. Lol. VERY strong midrange.
    Jun 2006
    Holland,MI
    416
    BUMP. Just ordered this 35-414-3 cam for a build with some mild port and bigger valve DO0E heads. It's probably too much cam but I'll have a converter. http://www.compcams.com/Company/CC/c...?csid=871&sb=2
    Apr 2015
    2,345
    Would a '91 351 car have a roller or flat-tappet cam? I'm looking at one to have as a spare when the '90 goes under the knife for everything swap. I have extra heads and cams, thought it might be fun to see what they do to a stock 351 2bbl in a vic.
    39,125
    roller 351 block came out in 1994 I think.
    Member Grand1's Avatar
    Feb 2012
    Michigan
    619
    Purely anecdotal but go with Lunati. I have their Barebones cam in my 78. Four years of awesomeness. Make sure to put Zinc or ZDDP in with oil changes for that cam. Please update with progress as I will be doing this with my 5.8 87Vic!
    1987 LTD Crown Vic 351w aka the "MI Mountie"
    2003 Lincoln Towncar , daily driver
    White collar, and a red neck P72Ford's Avatar
    Feb 2007
    In the 860
    7,176
    Roller block is 1994 and later; F4TE casting.
    I would highly recommend zinc additive with every oil change to anyone using a flat tappet cam.
    **2012 Ford Mustang Boss 302: 5.0, 6 spd, 3.73s; 17K miles Cruiser
    **2008 CVPI, Ex MSP Unit #420: 4.6, 3.55TL Flowmaster 10 knock offs, dark tint, JD Blitz Black, DD, CHALKBOARD
    **2012 Harley Davidson Wide Glide (FXDWG): 103, Cobra Speedsters, Cosmetics
    **2014 Ram 1500 QCSB Express 4WD Hemi/8spd TF/3L21 Truck Duties; Boesch Built, Cosmetics
    Member clutch47's Avatar
    Apr 2019
    660
    Ever consider having a cam made specifically for your application.?
    It's typically a sub $300 deal..
    All FORD All The Time
