Results 1 to 4 of 4
Thread: 1986 town car struggling to idle.
  1. #1
    Default 1986 town car struggling to idle.
    My 1986 town car come with one issue it likes to die when you first get it started up, but once you get it going itís fine. Itís an odd crap shoot.
    But when itís finally idling itís steady at 800rpm, but if itís struggling and you try to move the car it dies.
    So what do I need to look for?
    I cleaned out the Idle control valve And that did barely anything. Itís weird that once you get it going itís fine.
    So if itís warmed up or not has no effect? So what could cause this.
  2. #2
    Nov 2012
    Shelby Township, MI
    2,724
    Engine Coolant Temperature (ECT) sensor is a likely culprit.
    Also the Air Charge Temperature (ACT, also referred to as the Intake Air Temperature (IAT)) sensor could be at fault.
    ECT is on the front passenger side of the engine where the hose that runs back to the heater core is connected.
    ACT is on the front driver side of the lower intake.
    Those two sensors, in that order, is where I would start.
    ~ 1997 GMC Yukon - wannabe winter DD - I'll fix it eventually
    Gone but not forgotten:
  3. #3
    37,417
    do you have another known-working IAC? if the sensors are good, it could just be the IAC is bad.
    Is the SPOUT connector missing? That has a lot to do with idle control too.
  4. #4
    Apr 2015
    Southern Commiefornia
    2,072
    ACT and ECT sensors are a good start, and cheap enough it doesn't hurt to throw them at it anyway. Vacuum leaks is always the first place i go though.
