View Post
ADTR adjustable trailing arms!
That will definitely help. You will feel a difference for sure. And unless you plan to autocross it, I doubt you'll need a pan hard bar to make sure the axle stays centered left to right.
Stock arms with a panhard will do a better job of lateral location than really stiff arms with none. The binding problem is a much larger issue on a street driven car. Its also going to have a whole lot more harshness to the ride. Just my 2 cents.
and these people's for what thats worth
Fox cars have an identical rear suspension design, its just a little narrower. Add some spherical rod ends to those ADTR arms and you've basically got what MM sells, and that will get the job done nicely. Won't do anything for the harshness but that can't be helped.Last edited by gadget73; 05-18-2019, 09:20 AM.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostIf you want lateral stability for turns, you want a panhard or watts link. Stiffer arms really aren't going to do that for you. A panhard should make the shit road behavior a fair bit better, I've noticed the back end tends to dance around considerably even with good bushings. Its downright scary when the bushings are totally fucked in the back.
Thought I'd give this a bump since the order has been completed. And they're almost on to production.
Who all on here picked up a set?Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Originally posted by marquis_82_withneons View PostThought I'd give this a bump since the order has been completed. And they're almost on to production.
Originally posted by Elias View PostAs of last week we have 18 so 2 more for a run. Since I installed the rear arms I took 18” wheels off and went back to the hpp. Got to admit it the 16” ride is way better I love the rear arms ride is more stable and not as much body roleCharlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Originally posted by knucklehead0202 View Post[ATTACH=CONFIG]53216[/ATTACH]1985 2-Door: CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, ASP Underdrive Crank Pulley, Bilstein Rear Shocks, Rear Lowering Springs, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Ford Racing 4.10 Gear, Eaton LSD Differential - I own the fastest CFI powered box to the 1/8th mile: 9.658@70.74mph
1991 4-Door (Dad's Car): Pro-M EFI, 306ci, Forged Pistons, Ford Racing Aluminum Heads, COMP XE264HR cam, Cobra 1.7 Rockers, Edelbrock Performer RPM 2 Intake, 30lb. Injectors, Custom 65mm TB/EGR Spacer, Pro-M 75mm MAF, BBK Ceramic Shorties, Custom Summit H-pipe, Walker Mufflers, Jegs Built AOD, Roadrunner 3000 Stall Converter, Ford Racing 4.10 Gear - Best 1/8th mile time: 9.76@72.03
I'm on the fence. Sherrie has to ride 'nice'..
In the spring the rear is getting some attention in the pinion seal and traction-loc areas but I think I'm keeping the 3.08.
That'd be the right time to do it.. and body bushings.
The speedway springs/KYB shocks made me like the car WAY mo'betta..
I just don't want her to get all harsh and new car feeling.All FORD All The Time
They are very well made, but I agree with the above sentiments about rods ends. If you look at the arc paths swept by control arms on a triangulated 4 link car, there is always bind in a bushed configuration. And sometimes you're looking for that for anti squat, etc. Hopefully some research went into that on the manufacturers end. You don't need them on both ends.
I really like the later style rear suspension on the '03+ cars, and I think the S197 cars would be perfect with a watts instead of the panhard.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
I think the research was "It's like Fox body 4-link setups and those work, but a little longer" so let's do it.
im pretty psyched for the whole deal. im doing a 96 rear disk swap right now with 3.73 trac-lok. so i finally kicked myself enough and snatched the trailing arms so its rebuilt right all at once. talking to a few other box guys, since the arms didnt included poly bushings for the diff, we are going to keep stock ones in that location only to help with the binding (which i assume is why they were not included)... hopefully. trial and error i suppose.Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
