Results 1 to 5 of 5
Thread: two door windows
    Default two door windows
    Is there any way i can swap vent windows onto my two door that just has regular windows on both sides?
    39,125
    if you have the wingvent and the proper glass, yes. I've done it on a 4 door, I expect its about the same process. Basically you remove the old glass, install the wing vent, then install the other glass.
    21,547
    Along with the other glass slides for the forward half.
    Digital Dash Enthusiast Hearsesrock427's Avatar
    Apr 2014
    Upstate NY
    558
    Are the vent windows/wing windows the same on four doors and two doors? I'm looking to ditch the wing windows on Ebyt....
    Slicktopped 1989 Grand Marquis "Ebyt". Primary project.
    255/50/R16 BF Goodrich G-force Sport Comp 2 tires, big disc brakes, polyurethane suspension bushings + body mounts, BBK long tube headers, HVAC delete
    Summer 2019 plans: Aluminum driveshaft, additional chassis bracing
    Slicktopped 1985 Grand Marquis "Eva". Secondary project.
    Winter 2019 plans: Full chassis swap, maintenance.
    Jan 2007
    Westmont, New Jersey
    10,369
    Quote Originally Posted by Hearsesrock427 View Post
    Yes. But the main window glass is different.
