Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: Spark plug O-rings
    Freeman LibertyAddict's Avatar
    Feb 2013
    Puerto Rico
    30
    Default Spark plug O-rings
    Looked everywhere and can't find info on this.
    The o-rings for the spark plugs.
    Where are they?
    How to change them?
    Where to buy them?
    Are they even a thing in the 4.6L engine?
    Sep 2014
    Warren, MI
    5,390
    That's because they don't exist. Almost like Blinker Fluid or Muffler bearings. Some spark plugs have washers on them though, is that what you're talking about? I'm not a 4.6 guy. I know fuel injectors have O-rings though.
    Not a thing. Are you changing the spark plugs? If you dont already know changing the plugs on a 4.6 2v can be risky due to only having a few threads on pre 04 heads.
    Nov 2014
    Evans, GA
    1,352
    Good rule of thumb is 14/ft-lbs and no anti-seize. Hulk torque spec may result in spark plug ejection after a while.
    -1987 Grand Marquis Colony Park LS (325K Miles) - April 2017 POTM Winner
    Also retorquing them after a few heat cycles to ensure theyre still in spec and havent backed out.
    Jul 2014
    Canada
    1,672
    Also torquing/retorquing them only when the heads are stone cold. Torquing on feeble aluminum threads when they're warm is just asking for trouble. Since most shops would probably not wait, I wonder if that's where a lot of the problems come from.
    I think its the lack of information (or research on the person whos changing them), inexperience with aluminum heads (especially during the 90s-00s since Ford people were used to iron cylinder heads) and Fords lack of judgement. It took them from 91 all the way to 04 to finally give the 2v heads enough threads to lower the chance of a blowout substantially.
    Also it would seem that its more common on the 5.4 and in trucks. It would seem that perhaps trying the service the plugs on the rear cylinders are probably the big offenders.
    20,897
    There's fuel injector o-rings. And fuel line o-rings. Then the AC system uses o-rings too, but spark plugs use angled seats or metal gasket washers.
    Feb 2013
    Puerto Rico
    30
    I asked because I see oil on one of the spark plugs.
    Changed them all a few months ago and I noticed one particular plug was darker and dirtier than the others. I just pulled that one out and cleaned it. The car still idles rough, it shakes, sounds like it loses power, like it wants to shut off.
    I'm about to order some new ignition boots and I figure the wiring needs replacement too BUT when I type "Grand Marquis ignition wiring" I get varied results. I could also change the ones that are bad for now and then do the whole thing when I have time. Now a question: How do you check which one is bad? Do you unplug them without disconnecting the battery and with a multimeter check for 12v?
    Thanks for all the quick replies. One would think a forum about a car that is out of production shouldn't have so much activity, but it does! Great!
    20,897
    Could be oil leaking from the valve cover gaskets along the top edge next to the intake manifold and draining into the plug hole. Can't think of any other non-catastrophic failure mode.
    Feb 2013
    Puerto Rico
    30
    It's clean around the plug, no signs of leakage from the VCG.
    I had a leak on the driver's side VCG, bottom of the cover, towards the back of the car, and replaced the gasket a couple of months ago. No more leaks from that. Now FTR, that odd dirty spark plug is on the passenger's side closest to the front of the car, the complete opposite of that old leak.
    When I installed the new spark plugs I noticed the shaking calmed down for some time but it started to come back gradually and a few days ago it popped the check engine light.
    My suspicion of bad contact on the wires is grounded on the possibility that when I changed the SPs I moved the wires in a way that they made the right contact, and later after a gazillion potholes(easy to achieve here) they shifted back into damnation.
    Its most likely coolant from the intake manifold/coolant crossover. What year is your car? Im assuming its a 98+ because usually when this happens it shorts the coil over plugs (cops) and requires a new coil.
    You cant really test a cop, you can perform a resistance test on the secondary circuit but imo it doesnt tell you much. You could try a new coil boot but youll need a new coil eventually.
    For what its worth, I drove through a deep puddle that splashed all under the hood on my 98 p71. It didnt drench the top end and nothing was affected except coil number three crapped out on me. I replaced it with an ebay coil and didnt have another issue up until I sold it.
    Sep 2014
    Warren, MI
    5,390
    Yeah, what year is your car? Don't the early 4.6's have issues with valve stem seals? I believe seeing oil on the spark plug threads indicates oil is getting into the combustion chamber somehow, stem seals can be a way. It's definitely an issue with higher mileage LoPo 302's, the rear most spark plugs anyway.
    Hmm I forgot about that, yes thats true. Though I think that was an aero era issue. It could still be the case though.
    20,897
    Yeah... knowing the year of your car would help. And yes the valve stem issue was an aero thing that was supposed to have been fixed in 95 or 96. But even the better seals do eventually wear out. It just takes longer.
    Feb 2013
    Puerto Rico
    30
    What's the difference?
    Feb 2013
    Puerto Rico
    30
    It's a 98. 101k miles.
    It's not that the plug is drenched in oil, just slightly on the threads, and dark(carbonization?) on the spark tab.
    I ordered the coils on AMZ, all 8 of them, last night and they're on their way already. Under 30 bucks the set.
    Asked once at Advance Auto Parts and the guy told me something like 38 bucks per piece!
    Feb 2013
    Puerto Rico
    30
    BTW, coolant levels are fine.
    Feb 2013
    Puerto Rico
    30
    Valve stem seals... Got some homework to do.
    Jul 2014
    Canada
    1,672
    Quote Originally Posted by LibertyAddict View Post
    I wasn't sure initially if you were talking about spark plug wires (on an aero) or COPs, but since it's COPs, the boots are the rubber part, and sometimes you can get away with replacing only the boots. Getting a new set of COPs for so cheap is so much more convenient though, and you can keep the old but good ones as spares.
    Also, not sure what year the problematic all plastic intake manifold started, but the failure of the coolant crossover on my 2000 MGM was nothing more than a teardrop leak on the front passenger side that I happened to notice when it was warmed up. Enough coolant had accumulated in a spark plug well to cause problems.
Tags for this Thread
