1985 CV {351 street rod } *DUW* *UPDATED* page 2
O... MY... GOD... :woot: YES!1989 LTD Crown Victoria LX.
-3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
4 Door Muscle
Supermotors
Any dyno numbers or track times yet?1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Updated the interior section.
No times yet. Once the tranny goes in i will get top at least the 1/8th mile and get some new times with the drag radials.
Transmission.
Performance Automatic Competition C-4 rated to 750HP.
Interior and exterior updated.http://secondhandracing.com/Home.aspx
Looks great! I have really enjoyed watching your build up Duce! I like the rear tails with the black border and the classic LTD in the lights. Are you going to do any black accents with the new front? I really liked the blacked out front before.2000 Mustang GT "Blondie", 2000 CVPI "Sargent Crusty"
Originally posted by zwack88Looks great! I have really enjoyed watching your build up Duce! I like the rear tails with the black border and the classic LTD in the lights. Are you going to do any black accents with the new front? I really liked the blacked out front before.http://secondhandracing.com/Home.aspx
Originally posted by Blaze86VicYou can buy the grill on ebay brand new.http://secondhandracing.com/Home.aspx
C4's sound like a Bomb.????
ATT, SNIPER 308.FAREWELL BLACKHAWK-P74 INTERCEPTOR I WILL NEVER FORGET YOU MANG.MERC75-INTERCEPTOR, BORN IN 2003,DIED IN SEP/21/2010 AT 9:55AM AT THE SORT AHE OF 8 YEARS PROTECTING HIS OWNER TO DIE
Originally posted by sniper308C4's sound like a Bomb.????
ATT, SNIPER 308.FAREWELL BLACKHAWK-P74 INTERCEPTOR I WILL NEVER FORGET YOU MANG.http://secondhandracing.com/Home.aspx
Figured it was about time to update this.
i painted the hood and the scoop flat black, i also put the black front end back on.
I also replaced the original chromed steel bumper with an aluminum bumper off of an 85 wagon.
I replaced the E7 heads with a set of E8JE heads (early marine GT-40 heads)
when i did this i cleaned up the intake casting a little.
next day i ran a 13.37 @99 with a passenger and a glitchy nitrous system.
I added an additional cooling fan and a second tranny cooler,
i also boxed in the radiator to help with cooling (it does not get above 190degrees anymore).
i installed the Kirkey drivers seat, i now have a
passenger side seat also, just have not replaced it yet.
I have removed the back seat and rear deck, both have been replaced with .032" aluminum.
I have also recovered the headliner, it now has a raised "LTD" logo in it.
Front suspension now has the original springs back in it,
along with a set of Competition Engineering 90/10 shocks,
also the front sway bar has been removed. best 60' time is a 1.92.
here are my two 13 second timeslips.
here is my best run.
http://www.supermotors.net/getfile/4...sblueacura.wmv
here is the best dyno graph from the old heads. this was a nitrous pull,
the nitrous plate had the wrong fuel hole in it so it ran pig rich (well richer than 10.1)
the pull is from 3000 rpm to 5,000rpm, with valve float starting at around 4500.
it put down 213/280 on motor alone and the "125" shot only increased it to 270/308,
it should have been more like 330/420. that is through an automatic with a non-lock up converter
so there is a good 25% driveline lossLast edited by DuceAnAHalf; 05-04-2007, 08:40 PM.http://secondhandracing.com/Home.aspx
