Page 2 of 10 FirstFirst 1234 ... LastLast
Results 21 to 40 of 192
Thread: 'Sherrie' my 86 Oxford White CV Coupe
  1. #21
    Member clutch47's Avatar
    Apr 2019
    493
    I ran it long enough to positive it wasn't doing anything. I think it's time for a total rebuild. Compressor, Dryer, Accumulator and whatever else I can find.
    If anybody reading this has any parts.. I'm gonna start a collection.
    All FORD All The Time
  2. #22
    18,851
    just go to rock auto. I just picked up everything I need at a really reasonable price.
    Condenser, compressor, drier, new hoses (3x), orifice tube. I chose to just flush out the evaporator, though that is available and too can be changed out.
  3. #23
    Sep 2014
    Warren, MI
    5,756
    My advice is to make sure you buy a NEW compressor. My '85 ate two reman units before I sold it in favor of my current '88. Went straight for new with that one and haven't had a problem.
  4. #24
    Apr 2019
    493
    Derek, you aren't the only person that has told me that. I've never re-built an A/C system before but I have spent quite a bit of time with 335 series FORD engines.
    I'll get to learn something new here and get garage time in the process. Win/Win.!!
    Thanks.
    Once this is correct, I'll move on to bumpers. My front one is rotted through behind the tag mount.
    I'd like to go with aluminum, but we'll see when it's time..
  5. #25
    21,357
    I would also suggest getting a new DENSO unit. I went through 2 "new" compressors in 4 years with my 93 but the Denso I put on there has lasted 3 years now.
  6. #26
    Apr 2019
    493
    I'm learning more about A/C every day here. Apparently somebody else had their hands in the soup somewhere because there are 134 fittings on it. Sooo…
    What do ya'll use to flush these parts.?
    I'm going to try flushing out the condenser along with a new dryer and compressor.
    I'll take your advice Sly. Thanks.
  7. #27
    21,357
    I use AC flush and compressed air to force it through the coils. Comes in a metal can and is insanely harsh chemical. Eye protection, thick solvent resistant gloves, and a small funnel to help pour the stuff into the lines (I usually go through the bottom of the evap after pulling the orifice tube out and hold a rag/shop towel over the top exit with no dryer to catch the crap and just do my best not to spill a lot when putting it into the condenser).
    If you get the AC flush on your skin it WILL burn. There should be no lasting effects if you get it cleaned off quickly, but it will hurt. Stuff flashes off quickly.
  8. #28
    Apr 2019
    493
    Well..
    An old friend has a friend with an R-12 recharge/service unit and might have a line on refrigerant.
    Worth converting it back.??
  9. #29
    Apr 2010
    Southern NJ
    2,590
    I wouldn’t. It will work ok if properly converted. If you go back to R12 and need a small top off you may be stuck paying a ton for a can of old stock R12
    Past Panthers
  10. #30
    38,502
    It will perform somewhat better but limited stock of refrigerant and all that to deal with makes it a less appealing choice for me. If the system is working properly and the coils are clean, it'll get cold enough with R134a. Make sure the fan clutch is good though, or an electric fan is a help. I've heard good things about using R152, which is the stuff in computer duster cans, but no personal experience with that. Apparently performance-wise its somewhere between R12 and R134a. If my stuff wasn't already converted and working I'd be tempted to try it.
    Before buying parts I'd evaluate what is there. Do a pressure test first to see if its even got anything in the system. I can tell you that popping open a partly charged system will spray stinky oil all over, and you're not going to be having a fun time of it. Pull the orifice tube and inspect it. If its full of garbage, then you know something bad happened and the condenser is likely full of crap and the compressor may have blown up. If its not all nasty, put a new tube in, flush the condenser to get rid of any old congealed oil goo, put it together with a new drier and O rings on all the joints and go from there. Replacing the condenser with a more modern type of better efficiency isn't the worst idea if yours is leaky or clogged.
    You can flush the evap or not, its your call. Honestly the chances of anything really being in there is small since it would get stopped by the orifice tube. The condenser is where things will end up. That one wants to be flushed small tube to big tube, which is opposite the normal flow direction.
  11. #31
    Apr 2019
    493
    Thanks fellas. Forgive me for being a newbie to HVAC please. I'm just starting to grasp how my mini-split on my house works. LOL..
    Although the novelty of R-12 would be legit.. (I remember frost coming out of the vents on my 84 Capri...LOL.. man, do I miss that car)
    I think the 134 is probably the wisest choice.
    So do I need a special spring tool or extractor for the orifice tube and...where is it.?
    Anybody got a good part number for a compressor.? Rock auto shows nothing like I have and I want to buy a good one.
    I'm gonna dig into this again this weekend if I can get time.
    I think window switches are in my future too.. mine are intermittent. They are going to get cleaned up and lubed.
  12. #32
    21,357
    The orifice tool can be rented from most parts places. I bought one as they're not that spendy and I've done enough jobs since to pay for it in saved gas trips to the parts store to rent one.
    Here's the one I have. IIRC, the brass part on the right is the one to use with the Fords. Basically hook ir on the tube and then continue twisting it to help break the seals loose and pull it out.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    As for the AC compressor... Looks like RA doesn't have any decent brands. Not sure you'll be able to get around this issue though. I'm not finding any denso versions of the FS6 compressor. I've had bad luck with Four Seasons in my Aero, but my 88 I think has a Four Seasons from AutoZone in it and didn't have any issues. So it might be worth rolling the dice on that, but you may want to get one locally to have a "lifetime warranty" (if available) and get free replacements down the road if it does die.
  13. #33
    38,502
    The tube is in the lower pipe of the evaporator, just inside the connector. Evap is the part in the dashboard. Unhook the line going there and you'll see it down inside.
    I've debated buying an NOS FS6 compressor just as a backup but haven't quite pulled the trigger. I had a Four Seasons that went leaky on my Towncar in a couple years. The Motorcraft on it now sounds like a dying air raid siren but its been doing that for 7 or 8 years now. The old one on the Continental is very quiet, not completely sure of it's history but we suspect it may be the original from John's 1986 Vic.
  14. #34
    Apr 2019
    493
    Again, Thanks. I'm learning a whole lot about something I always wanted to know a little bit about.
    Over morning coffee JoeGoogle and I found this forum. https://www.autoacforum.com/messagev...threadid=14821
    The more I read about compressors and compare cost vs quality.. the sadder the situation becomes.
    I'm debating trying to adapt an FS-10 from a newer truck. There'll be a metric ton of them available for a long LONG time.
  15. #35
    38,502
    Given the choice of an FS6 or an FS10, I'll stick with the FS6. Not any less reliable and no nonsense to adapt it. If I were to adapt something else it would be a Sanden compressor, whatever that 7 cylinder swash plate one is. SD7 I think? I put one on my S10 to replace the junk GM compressor after that thing failed for the third time.
  16. #36
    Apr 2019
    493
    Hey ya'll,
    Haven't been here in about a week. Family/work/vacation...you know.
    So anyway. No A/C yet. Still haven't decided on the right compressor.
    Spent some time cleaning up the paint. It was full of trash.
    I've never tried a clay bar but I think I'm gonna.
    Any recommendations.?
    This was just a good scrubbing and some effort with my random orbital and some Zymol. I've been using that stuff a long time.
    I did some digging online for a good vinyl top cleaner/conditioner.
    Went with Mothers VLR.
    I scrubbed the top with a soft brush and normal carwash soap.
    I applied this stuff 3 times and worked it in. I'm impressed. I'll do it twice more this season. Hope to keep this top nice.
    It's lifting on the bottom edge on the passenger side.
    I'll try to glue it down after I learn what works and how to do it.
    Thought I'd put a few shots of the exhaust on too, as there were questions after My friend Carl did it.
    I like it.
    Next small project is mounting/wiring my tach..
    Then on to my other car project. 351C stroker into my '69 Mercury Montego convertible.
  17. #37
    18,851
    Looks good.
    I recommend mothers clay bar.
  18. #38
    Apr 2019
    493
    I never used a clay bar before so this should be fun..LOL
  19. #39
    Fort Wayne IN
    5,610
    Quote Originally Posted by clutch47 View Post
    Soo.. I couldn't leave well enough alone.
    The blend door servo is working, but doen't seem to fully cycle.
    With the A/C low pressure switch jumped and the compressor running, the drier isn't getting cold.
    HHHmmm.. Bad compressor.?? It's still R-12. I'm betting it's dead empty.
    I gots no HVAC gauges.
    So would a bad compressor make this system go wonky and even provide warm heat.?
    Man oh man I'll be glad to have this up and running properly.
    Every other thing on this car is superb and I'm really enjoying it.
    I had a 93 Mark VIII that got run to a quarter million miles and ..
    I might like this car even better than that one.
    I appreciate your advice fellas.
    A panther has no equal. Well, a GM B body is close but I don't want to be beat with a bar of soap in a tube sock.
  20. #40
    Sep 2014
    Warren, MI
    5,756
    Close indeed, but Ford was in the lead.
    Having driven both a Caprice ('89) and multiple box Panthers GM just wasn't up to snuff. From the dumpier 200R4 and carb'd motors damn near right up until the bitter end their box stuff was definitely in the rear view by comparison. When they went roundy in '91 or whenever they got leaps and bounds better. At least in terms of powertrain (especially when the LT1 hit the scene) interior quality and exterior fit & finish. I wouldn't mind trying out a '95 or '96 LT1 powered Fleetwood...
