Results 1 to 9 of 9
Thread: Wiper/Washer Switch Assembly
  1. #1
    Nov 2006
    Dirty Jersey Yo!
    7,735
    Question Wiper/Washer Switch Assembly
    Do these go bad often? Or does my car have wonky electrical issues? I ordered a replacement wiper/washer switch (which also has the emergency light button attached) after mine shorted out and won't turn off.
  2. #2
    Stow It! GM_Guy's Avatar
    Sep 2008
    Ontario, Canada
    3,183
    The MFS seems to always have been one of those items that is at the top of most folks suspect list. Given the amount of high(er) current devices running through it, its no surprise they go bad. I pulled apart the ignition switch from my 2008 to autopsy it, and it is pathetic how small the contacts are, and its readily obvious which one was arcing and causing me randomn no start issues.
  3. #3
    37,524
    not sure I recall any mention of wiper switch problems but like all things it can go bad.
  4. #4
    Nov 2014
    Evans, GA
    1,354
    Some of the ‘03+ cars get water intrusion into the wiper motor and it’ll cause them to go stupid. Worth checking if they’re acting up with a new switch.
    -1987 Grand Marquis Colony Park LS (325K Miles) - April 2017 POTM Winner
  5. #5
    37,524
    The parking cams on the wiper motors can also wear out and cause it to either not shut off or not park correctly.
  6. #6
    I post a lot...
    Apr 2010
    Southern NJ
    2,539
    Quote Originally Posted by Kodachrome Wolf View Post
    This
    https://www.crownvic.net/ubbthreads/...03#Post2771803
    2017 Buick Enclave 3.6 (Burgundy/Beige)
    2017 Hyundai Elantra SE w/tech (Silver/Grey)
    Past Panthers
    Quote Originally Posted by Lincolnmania View Post
  7. #7
    Nov 2006
    Dirty Jersey Yo!
    7,735
    Yah, I just pulled the cover yesterday during my lunch break; and it was so full of debris that it wouldn't snap shut again. I spent 20 minutes this morning vacuuming that section out. I might pull the entire cover off over the weekend and try to get everything cleaned out.
  8. #8
    Nov 2006
    Dirty Jersey Yo!
    7,735
    LOL, I just killed the plastic cover trying to get it back on. It refused to line up with the snap-catches. After 20 minutes of manipulating it; I just pounded on it and broke the cover in half. I should have just let it remain loose and taped it until I got home and had time to fiddle with it. I have to go to the junkyard anyways for CV parts; I will add another plastic cover to that list.
  9. #9
    Nov 2006
    Dirty Jersey Yo!
    7,735
    Fixed. Took about an hour and a half; which includes running to AutoZone for a plastic trim puller set, plastic button-fasteners, and a hex-star socket (T-20) set. Pretty much unbolt the assembly, unplug it, plug in the new unit, bolt the assembly back into the steering column; and replace column cover and lower dash trim. It was surprisingly simple.
