Results 1 to 5 of 5
Thread: '09 Air Suspension
  1. #1
    Member
    Apr 2018
    Ustroń, Poland, Europe
    107
    Default '09 Air Suspension
    I would like to back to original specification and change springs to air bags. I have new compresor and air bags with clips. Unfortunately I didn't saw conversion from air to spring, I just receive old air bag with solenoids in box. I understand that solenoids should be connect to some tubes - where should I find it? Maybe someone have photos or scheme for it ?
    '09 Grand Marquis LS - Light Ice Blue exterior, Medium Light Sone interior, Heated seats, 17" rims, J-mod, dual exhaust with Magnaflow 11224 mufllers
  2. #2
    38,507
    The air lines and the connectors are normally found up near the top of the spring area. If yours have been cut you'll just have to hunt for it. The air line runs along the frame rail on the driver's side of the car, the wiring comes out of the trunk.
  3. #3
    No mean-spiritedness here. IPreferDIY's Avatar
    Jul 2014
    Canada
    1,859
    Here's a marked-up photo I got from a page by the late great 2vmodular dealing with rear shocks (click to enlarge):
    His yellow arrows show the older location for the rear shock upper mounts, and his red arrows show the location of the rear sway bar mounts. The driver's side solenoid is at the upper right of the bottom yellow arrow, and you can probably figure out the rest from there.
    mods: air filter box "tuba" (in place of the "trumpet"), headlight relay harness, J-mod (around 186,350 km), 70mm throttle body, NKL4 PCM (from a 2000 CVPI, nothing great there apart from highway cruising), KYB Gas-A-Just shocks (after >202,000 km on originals)
  4. #4
    Member
    Apr 2018
    107
    Next 2 day I will be install new compressor and new air bags. Question - if system is in good condition but it's turn off with switch in trunk, car should stay on this same level after 12 h ? Is there any standard about time with turn off air suspension and holding a level ?
  5. #5
    38,507
    It should stay at trim height for weeks if things aren't leaky. The car I messed up last year hasn't been started since January and the air suspension is still up.
    I believe the system does a final adjustment about 2 hours after the engine is shut off and then stops.
