Steering Shaft Question
    I'm doing the steering joint on the '87. Old one is super wasted from oil exposure. Separated the shaft from the steering gear box no problem.
    Question is, does the shaft actually separate into two pieces where it slides? It feels like there's a stop once its "fully extended". Don't want to damage anything, just figured it would be easier to deal with the rivets with it 100% out of the car. If it can't be separated, there's enough room to do the work in car.
    Isn't there a u-joint under the brake booster you can remove the set screw from?
      Unbolt from steering box. Unbolt shaft near brake booster and after a lot of cussing and swearing (maybe only northern cars) you will have the shaft in your hands.
        Yes, it separates, but is a pain as I recall since it takes a fair amount of force. There's a metal clip at the lower end of the top half that provides quite a bit of tension inside the lower half, iirc.
        Well that's for the part in the steering column, although the part in the engine bay may be the same.
        I don't think I covered this in the threads where I was working on the steering shaft (upper part in the steering column), but here is what I have related to the subject just in case:
        http://www.grandmarq.net/vb/showthre...ft-Interchange
        http://www.grandmarq.net/vb/showthre...aration-advice
          Its two piece but there isn't much need to take it apart if it will actually slide. Mine was rusted fast and had to be heated considerably to move in order to get the box out and back in. Shoot some oil in there to keep it free though. Unbolt it under the brake booster and pull it that way.
            I never paid any attention around the brake booster for the u-joint. I know it’s there, but I didn’t inspect it further. Even though this is a southern car, I expected a fight given the mileage, but the shaft slipped right off the steering gear no fuss.
            Since I’m running a later air tube, I had plenty of room to do my drilling of the rivets in the engine bay after I had it off at the bottom and it moved freely enough on the shaft to make it easy enough, so I didn’t remove it at the top.
            Old rag joint was like jelly and was actually torn apart at the bottom, while the rest was badly separating. It was oozing oil from some encounter long ago. The car always had loose steering which for the longest I chalked up to old car, but once I realized it was the joint, I knew it needed fixing. I’m glad it didn’t tear apart entirely while driving. It’s nice and tight now.
            Old:
            New:
              Nice. I had a hell of a time removing mine from my car. I removed it entirely to adapt it to the later steering box. It was not fun. Then fabbing up the adaptor between new lower piece and existing upper was also an experience.
                Did you use regular bolts in place of the rivets? I thought about doing that once my fails but Im afraid the bolts would back out as I was driving lol.
                  I used a Dorman kit that included everything. The nuts they use are nylon lock type despite the assembly instructions showing lock washers.
                    Oh ok good to know. My old 98 p71 had a loose rag joint but I hesitated to replace it and I couldnt find a whole steering shaft for a reasonable price. Im surprised the steering in my 87 is as tight as it is and it looks like pretty much all of the steering components are stock.
                      the rags usually fail from oil exposure, and the only thing that should make a huge mess right in that area is something in the power steering system leaking.
                        I suspect mine leaked fluid onto it some time ago, and it's been left like that ever since. Also, my car is missing its "stone guard" as the literature goes, which is that two piece plastic cover that goes over it. I'm sure that also helps protect it some. I snagged a replacement off a junkyard car. That car's joint still looked really good, but it was clear that pump was leaking directly onto the cover as it was all greasy and nasty. I'll be installing that once I clean it and adjust the shaft. I thought I had it on straight, but slid it on tilted slightly right. ¯\_(ツ)_/¯
                          Which Dorman kit and are you completely satisfied with its fitment for the job?
                          I'm seeing 31000 or 31005 as applicable to our actual vehicles and 31002 as a universal with no applications.
                          Current driver: Ranger
                            Dorman 31000. As fitment wise goes, I'll give it an 80%. It'll do the job properly once it's installed, but it'll also make you go "Wait, is this right?" during the install.
                            The disc really could do with the four holes being maybe a centimeter further out. You wind up with bolts passing through it at angles until you start tightening stuff into place, and if you look at my picture, there's a little metal tab you can see that is supposed to go over the disc some. There's two of those, one at the top and one at the bottom, and they're recycled from the pieces you drilled the rivets off of. I had to bend the lip on them up just a touch for it to clear adequately without it just cutting into the disc while tightening. The disc has enough give that you can make it all work. One thing I did find was that when re-installing the pinch bolt, the nut holding that upper piece on needs to come off so the bolt can actually be re-inserted, but that's just simply because the nut is much bulkier than a rivet head.
                            Looking at the difference between the 31000 and 31005, I really can't make heads or tails of that deal. It looks like the hardware is the same. Only thing I could consider is if the disc is a little larger, but all the stock images appear to be the same. If I remember, I'll see if I have both kits at the store and I'll try to compare them.
                              So the only product different I can find in the listing is the 31000 says ‘Material: Rubber’ and the 31005 says ‘Material: Steel’. Unfortunately the 31005 is special order so ordering it for observation isn’t possible.
                              All the dimensions are the same and unfortunately use the same stock photo, so I don’t know if the 31005 is reinforced in some way or if Dorman slings two of the same part, one just being slightly more uncommon. I think for most the 31000 will work fine as a OE replacement.
