WTB rear differential parts.
    Doing the axle swap on my 82. The 96 axle is going to be traclok and the differential I have needs a set of spider gears. Ive raided the yard a few times looking for rangers and panthers but trakloc is proving hard to find around me. Does anyone have a spider gear set for 28 spline limited slip that I could buy? Thanks guys
    are the spiders on the open carriers the same? Not sure axle spline count has anything to do with it, unless you mean the side gears where the axle actually comes into the carrier.
      Nope. Open carriers have dished spiders and TL carriers have flat backed spiders... and that's the side spiders that the axles slide into.
        ah, I was thinking the ones on the cross-pin. I know the ones on the axle side are different for the clutches.
          i thought about trying to get away with just the pin gears, but figured it'd be best to keep them all from same vehicle for wear purposes.
          also, i have located some so its all good now. no longer need them.
