Results 1 to 18 of 18
Thread: New to CFI and EEC lll
    PimpDaddy 82EmilioPucci's Avatar
    Jun 2019
    Albia, Iowa
    7
    Default New to CFI and EEC lll
    Hello Im Carson and Ive got this 1982 lincoln Mark VI, I was wondering what modifications I should make to make the car happier in its current form, nothing to make it "fast" just more reliable, currently its getting not enough air or to much gas and will stall at stop sign, most of the time even if you petal it, it has 83,000 miles fuel filter has been done, not recently, an getting to that, the in tank pump, and plugs. Thank you for your inputs.
    38,052
    Replace the vacuum lines and the timing set. Timing on this is off a crank sensor, but the cam gear has plastic teeth and it doesn't hold up as well as the later steel ones. If it jumps the valves will bend.
    Also might be worth removing the EGR valve and making sure its clean under there. If the EGR sticks open a bit it will be prone to stalling at idle.
    Jun 2019
    Albia, Iowa
    7
    Im buying vacuum line this weekend, i think the timings ok, i was reading a post from about 9 years made by MattsLincoln, and some one was talking about a cooler, do you know anything about that? Thanks for the recommendations
    21,180
    If the timing chain has never been changed, it's NOT okay even if it runs correctly now. It could fail at any time and lunch the engine.
    Sep 2014
    Warren, MI
    5,608
    There's an old but good expression I haven't seen in a while; "Lunched." LoL.
    38,052
    Some have a cooler between the EGR valve and the intake. If you've got an oval thing with two coolant lines, thats the cooler. Sometimes that also gets packed up with carbon and causes trouble.
    Apr 2010
    Southern NJ
    2,560
    I would likely see some pictures of your car. 82 Pucci’s are quite rare.
    Past Panthers
    Member clutch47's Avatar
    Apr 2019
    246
    I'm still at lunched.
    All FORD All The Time
    Sep 2014
    Warren, MI
    5,608
    I don't eat lunch but take one.
    21,180
    You're welcome.
    Jun 2019
    Albia, Iowa
    7
    Ill get some more pictures tommorrow. @tjc78
    Jun 2019
    Albia, Iowa
    7
    Jun 2019
    Albia, Iowa
    7
    Jun 2019
    Albia, Iowa
    7
    Attached Thumbnails Attached Thumbnails 15612141516136473311097227988448.jpg
    Jun 2019
    Albia, Iowa
    7
    Sep 2014
    Warren, MI
    5,608
    I've never seen that electronic cassette deck thing. What is the number "4" supposed to mean?
    38,052
    Cool. Looks like the same woodgrain used in the 83 Mark VI Signature, or awful close to it. I have that in my car, though I need the piece where your buttons are but from a car without digital dash.
    Learning The Ways Of Box Panthers MattsLincoln's Avatar
    Jan 2010
    Shavertown, PA
    2,535
    Yes the cooler sits between the egr and the intake i removed the cooler, plugged the coolant source, ran shorter studs to attach the egr to the intake without the cooler. The chunks of carbon that come out of that cooler had me go wtf. Best thing to do is save up about $200 and Sefi Swap your engine. Would require and 84-85 TFI Distributor, 86-89 ECM and harness. E7 heads are a decent swap but not needed for the conversion iirc. I had put E7 heads on my Blass when i did the sefi swap.
Tags for this Thread
