Whale electrical terminals , What to buy? Help
    I have GM (general Motors) terminals but I am having trouble finding the various terminals used by ford. I don't know the general timespan of their use but I find them in the 03 and the 08. I am sure I am just not looking under the correct name.
    I am looking for the round and flat male and female terminals themselves. The actual pins and sockets. For example the metal terminals used in these connectors as well as other common connectors.
ID:	1304982Click image for larger version
    Thanks,
    Jay
    Looks like the Wedgelock connector pins they were running in the 80s. Need to know the diameter of the pin, there are a couple different ones.
    https://www.clipsandfasteners.com/O-...show=45&page=1
    if that doesn't link properly, just search "wedgelock" there and you'll get their listings. Looks like .060 and .110" diameter pins.
    Auveco makes them, they have a lot of offerings but clipsandfasteners is one of their distributors. Might have to check through their catalog to find the specific one if its not that.
      That sure looks like those. These particular ones are 1/16" or just slightly over 0.06" Have to check wire size and probably get some mini-box types also.
