Results 1 to 16 of 16
Thread: Adjustable Electronic Flasher Question plus funny?
    Dec 2011
    Yonkers NY
    3,956
    Default Adjustable Electronic Flasher Question plus funny?
    I am looking to solve a problem with my leds in the Marauder . Couple of regular Eflashers will not work as they need more current to function. Here is a link to the details in that thread.
    http://www.grandmarq.net/vb/showthre...ith-LCM-bypass
    There is available an adjustable relay seemingly oriental in origin.
    1) Would this be likely to solve my issue and avoid resistors?
    2) I am currently using a 2 pin flasher. I think I can just ignore the 3rd pin?
    3) There are 2 models CF13 & CF 14. I don't know what this means and having crap luck on internet search to explain the difference. I am currently using a regular old fashioned icebox relay socket.
    4) Also WTH is "About dodges three times"?
    3Pin Adjustable Flasher
    https://www.amazon.com/TOMALL-Adjust...-1-spons&psc=1
    Dec 2011
    Yonkers NY
    3,956
    Actually I don't think my info was good on the 3 pin flashers. They apparently are triggered by providing ground. This is unnecessary with the 2 pin units. Still want to know WTF "About dodges three times"
    There are however 2 pin adjustable relays.
    Like this https://www.amazon.com/QUhang-Motorc...motive&sr=1-12
    Stow It! GM_Guy's Avatar
    Ontario, Canada
    3,227
    That two pin actually does work, I have a couple here that I was experimenting with, got mine on ebay for a couple bucks, exact same as the amazon one down to the silver lettering.
    Are you all LED, or do you still have conventional bulbs on one end? If you got one end still conventional, a tridon electronic flasher (often refered to as the electronic heavy duty flasher) will flash with a single conventional lamp in circuit.
    Alex.
    Dec 2011
    Yonkers NY
    3,956
    I went all LED. If you look at the other thread I found there are two pin flashers that require only a very low Amp draw to work. Most at a 0.2Amp minimum. So that is less than 2 of my LED bulbs. Meaning should work with any setup with at lest one one each corner. I ordered one. Should be fine with my 3 bulb setup.
    Most have an extra ground wire, not an extra pin.
    Does the one I posted above click?
    Member BlackVic_P71's Avatar
    Sep 2013
    New York
    586
    I have one of these for the sequential lights on the front of the wagon, it slows down the flash so that all 3 lights will illuminate. The standard timing on a regular electronic flasher is just a bit too fast.
    KeepItClean no load adjustable flasher
    Sent from my SM-G975U using Tapatalk
    Dec 2011
    Yonkers NY
    3,956
    Sequential?
    Light under high beam, Light under low beam, turn signal ?
    Sep 2013
    New York
    586
    Sequential?
    https://youtu.be/W3GFSPTixUQ
    Dec 2011
    Yonkers NY
    3,956
    Yup very cool.
    21,169
    Nice.
    I donít know why but my head blew off seeing that!
    38,015
    Proper light bulbs and thermal bi-metal flashers are your friend.
    Dec 2011
    Yonkers NY
    3,956
    ludlight
    38,015
    indeed, but they work without any nonsense. They also make the proper noises.
    Dec 2011
    Yonkers NY
    3,956
    Incandescent is certainly tried and true. They are certainly much simpler (a rare virtue these days). I can't even find a LED dimmer & bulb combo that meets my specs for regular home lighting. "Full" dimming down to candlelight level, a locator/illuminated switch, No light burst when switched on. Then 4th (reaching for Mars here) Electronic Multi-location dimming that meets the previous 3 specs.
    Yet I really like the Marauder running LEDs. Would I do another LCM car, Yes if I liked the car. Would I do a pre LCM car, You Bet, swap in a low current trigger flasher, or two as necessary, and enjoy. A four beam headlight car, Do it if can afford the H1 & H4 housings. I didn't have LED headlights on the 89 but, as much as anyone can say something theoretical is a fact, I would go LED if I did not have new H1 & H4 Bulbs in place and currently owned a 4 beam car.
    Jan 2007
    Westmont, New Jersey
    10,300
    There's a write up on bypassing the LCM and using electronic flashers to control LED turn signals on crownvic.net. It is basically isolating the turn/hazard wiring and putting them to electronic flashers and adding a ground. It's more or less the same thing that you would do on boxes. except on a box you don't have to modify the cars wiring to achieve your goal.
    Vicky
    Blue
    Gone! But Parts from it will live on in others!
    Dec 2011
    Yonkers NY
    3,956
    Here is mine.
    A box would be easy just change to the grounded low Current flashers and change bulbs.
