Page 1 of 5 123 ... LastLast
Results 1 to 20 of 92
Thread: The Blues Bison
    I post a lot... mitymerc's Avatar
    Nov 2005
    2,206
    Default The Blues Bison
    Introducing The Blue Bison, so named because it is big & my son donated a stuffed bison to ride in it.
    I think it will finally be roaming the plains this summer.
    Over the past few weeks we have cleaned up almost a decade
ID:	52243of stuff that got "stored" in, around and under it. Reinstalled the trans and exhaust, ordered rear wheels, reinstalled the TFI amongst other things. Right now fighting to get it started. The TFI was "borrowed" under hurried circumstances. I neglected to mark the dist. To make things more interesting I was just informed the "fresh" gas I just poured in is from last year's lawnmowing season. Got fuel pressure but it will not burp fart or make any kind of starting noises. Can't reach in to plug cyl #1 w/my finger, may try cyl #5... I believe the TFI I put in is good it was the spare from dragstrip box.
    '10 Escape LTD. V6 AWD, K&N, Bullitt wheels.
    '91 Mercury Grand Marquis Colony Park Station Wagon. K-Code, 4.10's, Repacked Trac Loc, MK VII LSC Engine, 'Stang Upper Intake, 'Stang Air Tube, K&N, 65 mm T-Body, 'Stang Headers, 'Stang Cat Pipe,'Stang Torque Convertor, 2 Chamber Thunderbolts.
    18,693
    Is this the blue car?"
    Nov 2005
    2,206
    Yup, it really does exist. LOL
    18,693
    Hope the rebirth goes well. It always sounded like a fun car. Nice to get it back in action.
    Nov 2005
    2,206
    I thought I would be working on the fuel pump issue today....
    Dealing with this instead.
    Dec 2011
    Yonkers NY
    3,964
    crapola
    GMN Regular slack's Avatar
    Mar 2013
    Long Island, NY
    1,228
    That sucks. I have a really nice sycamore tree in my yard that's as old as the house and would hate to lose it. It's healthy as an ox but the wind lately has been insane..
    Nov 2005
    2,206
    Soooo, The exhaust system we just reassembled is in the way of dropping the gastank. Fun.
    Nov 2005
    2,206
    Finally got the tank out.
    I recall the adventures of reinstalling Donald 's tank @ Scottfest. It took a crew of experienced mechanics to get it back in. Here it's just lil ole me. LOL
    Met with 2 tree companies today, one ran away screaming, the other gave us a firm number & will return tomorrow to giter done. The boys & I have to help haul wood for that price though....
    38,046
    mostly the misery part is the short studs. If you can get them to back out some it helps, or just sub them for threaded rod will make your life easier. Apparently the stock fasteners were a snap-off design, which is why they're just barely long enough to hold it when tight and an absolute bear to get back together.
    Nov 2005
    2,206
    Gotcha. 1 came out as a bolt. The other is still Studley like.
    Did not touch it today, worked on getting the tree out. I will need a new fuel float assy. Any idea where to get one? Green doesn't have it...
    Did not get the pump out yet, I am expecting another rusted out horror show.
    Nov 2005
    2,206
    I wonder if the 89-91 type will fit.
    5,212
    Float or fuel level sensor unit?
    Floats are easy, shared among lots of Ford stuff from 60’s-80’s: https://www.amazon.com/Brass-Ford-Fu.../dp/B01GFDB428
    The fuel level sensor is unabtanium. But you can probably fix yours. Or at least use sedan parts to fix yours. Here’s a write up I did: http://www.grandmarq.net/vb/showthre...ght=Resistance
    1988 Crown Vic Wagon - daily
    Nov 2005
    2,206
    Thanks I'll check it out.
    The meter shows infinity...
    Nov 2006
    Dirty Jersey Yo!
    7,794
    ^^^^^^^^^^^^^Yes, that is what I had to do. SPent a lot of time attempting to get the new tank on the oem studs. Gave up and got threaded rod^^^^^^^^^^^^^^^
    Nov 2005
    2,206
    The new tank arrived. The seam on one side and all corners were bent.
    They are shipping a new one.
    No replacement level senders available anywhere.
    Sent it out to be refurbed.
    Nov 2005
    2,206
    Ordering some Eastwood stuff to address a few issues on the yellow, white, black and blue cars....
    Nov 2005
    2,206
    Exhaust is BBK shorties into stainless Pypes carted X pypes to locally bent steel tails.
    Repainting tails, Rustoleum engine primer. Will be painted w/Rustoleum Engine Aluminum.
    Nov 2005
    2,206
    Pondering weather to paint the new gas tank or not. It is coated with invisible sticky stuff that would need to be removed first.
    Was thinking self etch primer & Rusteoleum, or maybe bed liner?
    5,212
    The sticky stuff seems to be good at keeping moisture out. My new tank has been on for several years and looks like new. No salt exposure though.
