Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 81
Thread: The Blues Bison
  1. #61
    I post a lot... mitymerc's Avatar
    Nov 2005
    2,164
    Arrgh, now drvr window won't open w/o help.
    I'll just leave it open when I go for insp.
    '10 Escape LTD. V6 AWD, K&N, Bullitt wheels.
    '91 Mercury Grand Marquis Colony Park Station Wagon. K-Code, 4.10's, Repacked Trac Loc, MK VII LSC Engine, 'Stang Upper Intake, 'Stang Air Tube, K&N, 65 mm T-Body, 'Stang Headers, 'Stang Cat Pipe,'Stang Torque Convertor, 2 Chamber Thunderbolts.
  2. #62
    18,649
    Some silicone spray on hand?
    Shoot some down the sides of the window. May be enough to help it out.
    Since you have to get in there eventually for the door lock clean up the tracks nice and good and spread some new schmoo on the regulator to get her going again.
  3. #63
    Nov 2005
    2,164
    Sillycone did not help. Ordered motor.
  4. #64
    Nov 2005
    2,164
    Replaced the steering wheel cover of pain
    With this...
  5. #65
    18,649
    Nasty under there?
    I sewed on a nice leather wheel skinz ages ago. For how little use the car gets it has not aged the best but it was nice when new. lol Baseball stitch and all to make it look factory.
    Cannot go wrong with ford though.
  6. #66
    Nov 2005
    2,164
    Bonus!
    Ford included the power for lighted arm rests.
  7. #67
    Nov 2005
    2,164
    Nasty under there?
    Not really, just small diameter & hard on hand.
    I have wondered if a Fox Mustang wheel would drop on...
  8. #68
    Nov 2005
    2,164
    Replaced drvr lock actuator & window motor.
    Going to rustproof the interior when the goop arrives.
    Many parts gave been collected while car was down.
    Installing 90 speaker pods & new speakers on front doors, have the goodies for express down , I think I have all the stuffs for the lighting in the armrests.
  9. #69
    Nov 2005
    2,164
    Shut off w/no warning on way to Church tonight, fired back up & did it again almost immediately and would not fire. We pushed it into a parking space. My wife & other son were lagging behind, gave us a ride.
    Went back later w/unknown TFI, started right up, let it idle for about 10 mins while we put tools & stuff away. Picked up my wife, returned to car and all seemed good,,,,,, till it shut off again 5 blocks from home. Restarted & made it to garage.
    Nothing looks funny though there was a slight "hot electronic smell".
    Will pursue tomorrow, um later today...
  10. #70
    Nov 2005
    2,164
    Installed new TFI, stalled after about 10 min @ idle. Restarted immediately no prob, stalled again. Swapped coil, ran for about 10, died, restarted, been idling about 1/2 hr, no stall.
  11. #71
    37,906
    try a distributor if you haven't. Bad pickups will give the same symptom. Also worth shaking the wiring at the coil. I've had wires break right at the connector inside the insulation before.
  12. #72
    Nov 2005
    2,164
    Will do. I have a spare HO, I don't know if it still has a dist though.
  13. #73
    Nov 2005
    2,164
    Found dist.
    On top of engine wrapped in a t shirt...
    No memory of why it was removed.
    It is now in BB, been running for 15 min, no failure as of yet.
  14. #74
    Jan 2007
    Westmont, New Jersey
    10,289
    I'm sort of thinking that next time I have to do a tank, I'm pulling the studs and making new, longer ones. Allthread should be fine, just making the things an inch longer would make life a lot less difficult.
    The tank doesn't suck when the nuts come separate from the studs. Took me 10 minutes to do the tank in the coupe because the nuts actually came off the studs.
    Vicky
    Blue
    Gone! But Parts from it will live on in others!
  15. #75
    37,906
    I didn't have problems with the nuts coming off the Towncar, it just seemed like the straps shrunk as soon as they came off. If I'd had 1/2" more of thread it wouldn't have been an issue but I had a very hard time getting the strap shove up far enough to get the threads on the nut to catch.
  16. #76
    Nov 2005
    2,164
    I had to make the studs extra long to get it in. I was not able to get the straps onto the studs. Like Thain said the straps almost seemed like they were too short.
  17. #77
    Nov 2005
    2,164
    Quote Originally Posted by mitymerc View Post
    Found dist.
    Ran for an hour, did not shut off.
  18. #78
    Nov 2005
    2,164
    I've washed it 3 times now, actually looks pretty good for having sat for 9 yrs.
    I still want to clay, & wax it.
    Cleaned the front armrest switch plates, they look pretty good.
    I could not find the lamp harness for the lighted armrests today, attempted to cobble connectors & sockets. When I got home from the yard I realized I got the wrong connectors...
  19. #79
    Nov 2005
    2,164
    Sprayed Eastwood internal frame coating inside the front doors as a preventative. The bottom edges of the doors have the barest beginnings of rust @ the seams, picked the seam sealer off drv side. I'm going to use rust encapsulator & re seam seal it.
  20. #80
    37,906
    Their rust goop is good stuff but wear gloves. Its pretty difficult to get off your hands. I used the converter and the encapsulator inside the bumpers on the Conti. Shiny side on the ones I got are nice, inside was not so nice. Figured I should put something in there to hopefully keep them from rotting from the inside out.
