The Blues Bison
    Arrgh, now drvr window won't open w/o help.
    I'll just leave it open when I go for insp.
      Some silicone spray on hand?
      Shoot some down the sides of the window. May be enough to help it out.
      Since you have to get in there eventually for the door lock clean up the tracks nice and good and spread some new schmoo on the regulator to get her going again.
        Sillycone did not help. Ordered motor.
          Replaced the steering wheel cover of pain
          With this...
            Nasty under there?
            I sewed on a nice leather wheel skinz ages ago. For how little use the car gets it has not aged the best but it was nice when new. lol Baseball stitch and all to make it look factory.
            Cannot go wrong with ford though.
              Bonus!
              Ford included the power for lighted arm rests.
                Nasty under there?
                Not really, just small diameter & hard on hand.
                I have wondered if a Fox Mustang wheel would drop on...
                  Replaced drvr lock actuator & window motor.
                  Going to rustproof the interior when the goop arrives.
                  Many parts gave been collected while car was down.
                  Installing 90 speaker pods & new speakers on front doors, have the goodies for express down , I think I have all the stuffs for the lighting in the armrests.
                    Shut off w/no warning on way to Church tonight, fired back up & did it again almost immediately and would not fire. We pushed it into a parking space. My wife & other son were lagging behind, gave us a ride.
                    Went back later w/unknown TFI, started right up, let it idle for about 10 mins while we put tools & stuff away. Picked up my wife, returned to car and all seemed good,,,,,, till it shut off again 5 blocks from home. Restarted & made it to garage.
                    Nothing looks funny though there was a slight "hot electronic smell".
                    Will pursue tomorrow, um later today...
                      Installed new TFI, stalled after about 10 min @ idle. Restarted immediately no prob, stalled again. Swapped coil, ran for about 10, died, restarted, been idling about 1/2 hr, no stall.
                        try a distributor if you haven't. Bad pickups will give the same symptom. Also worth shaking the wiring at the coil. I've had wires break right at the connector inside the insulation before.
                          Will do. I have a spare HO, I don't know if it still has a dist though.
                            Found dist.
                            On top of engine wrapped in a t shirt...
                            No memory of why it was removed.
                            It is now in BB, been running for 15 min, no failure as of yet.
                              I'm sort of thinking that next time I have to do a tank, I'm pulling the studs and making new, longer ones. Allthread should be fine, just making the things an inch longer would make life a lot less difficult.
                              The tank doesn't suck when the nuts come separate from the studs. Took me 10 minutes to do the tank in the coupe because the nuts actually came off the studs.
                                I didn't have problems with the nuts coming off the Towncar, it just seemed like the straps shrunk as soon as they came off. If I'd had 1/2" more of thread it wouldn't have been an issue but I had a very hard time getting the strap shove up far enough to get the threads on the nut to catch.
