89 White Crown Vic LX 4-door sedan parting out
    One of my customers had this car sitting in his driveway for 5 years. The flywheel is stripped off so car wasn't run. Lots of good body parts. Blue interior is shot! Tripminder lights up and shows date/time. Has dual power seats. Dome light with map lights. WagonMan VEIGHTPETE@GMAIL.COM
    89 Colony Park
    90 Colony Park
    70 HEMI Daytona Convertible
    WagonMan does the car have the wide rocker strips? If so how much will you charge me to send me the fender trims for all corners. You may send me a PM.
      Thanks for the reply.
        Perfect nose. doors are so-so. Trunklid good. Interior is shot! WagonMan Hey Slack, wanna make your car right again??? LOL!
        89 Colony Park
        90 Colony Park
          LOL!
          I actually am missing the chrome trim piece on the edge of the trunk lip. Not sure if you want to part that out though vs selling the whole trunk.
            PM sent!
            89 Colony Park
            90 Colony Park
              Do you happen to have power trunk actuator?
                No trunk actuator. Although the interior is shot these pieces are good. Map pockets for front doors, "Premium Sound" speaker grills,
                and rear of front seat Map pockets. VEIGHTPETE@GMAIL.COM WagonMan
                89 Colony Park
                90 Colony Park
                  Im looking for the retaining clips for the rear door panels, glove box, air snorkel, washer fluid resivour if in good shape, hood insulation if it stayed the same as the pre 88s, ac manifolds, and the two top studs for the hvac box. Do you have any of them?
                    Is the wiring to the fuel pump ok?
                    There is a section of wire that goes from the pump on the outside of the tank, up to a connector above the rear end just under the body on my '89 wagon, I need that.
                    Thanks
                    Sent from my SM-G975U using Tapatalk
