Happy to join this community! Mostly looking for help though...
    You may need to investagate the engine, based on what you describe you may need an engine.Did you check the condishion of the Spark Plugs? If they were coverd in oil or black and coverd in oil get an engine.
      Every spark plug I've taken out of that engine have looked just fine, quite normal, maybe a wee bit whiter.
      Timing chain has been changed with a double roller one.
      What are the symptoms of a worn cam or bent valve?
      No valvetrain noise, doesn't smoke or consume oil.
      It's just weird since the car runs so nice when giving it a bit more throttle. Every now and then the idle is buttery smooth too
