Happy to join this community! Mostly looking for help though...
    there is a test port somewhere on the CFI unit. Might have to remove the air cleaner lid to see it, but its on there someplace. It looks like a tire valve.
      Yeah there's the schrader valve right on top, so, just screw a FP gauge there?
        yes
          So much for testing the fuel pressure -tool doesnt fit.
          Anyways got to checking the timing...
          Spout disconnected base timing was at 20°. Set it back to 10° as it should.
          Runs way better, but still a bit too rough to call okay.
            What does this vacuum line go to? Short one that passes through the firewall. Via the check valve that is atrached to the vacuum distribution block thats attached to the firewall.
            And is it supposed to leak?
            EDIT: it goes to the heater/ac controls (i only got HOT on the test drive)
            But it still leaks.
              Check if there are and open vacuum ports on the cfi unit itself. Thats for your ac and cruise control. And no it shouldnt leak.
                As is:
                Plugging in the EGR makes the thing run a little worse, with egr off the idle is actually pretty alright, a consistent shaking.
                Still jerky and stuttery at low throttle, got only a little better after the base timing adjust. If I disconnect and reconnect the battery, would the computer realize the new and correct base timing and magically start working properly?
                  On the CFI apparatus I have 3 lines connected, one to the EGR solenoids, one to the PCV valve and one to the big-ass check valve down on the passenger fender.
                  If someone has more than that, please elaborate.
                    That line goes to the vacuum tree then. In the last pic I can see an open port. Thats probably why it isnt idling very well.
                      The check valve in the picture is what goes there, I took it off so you could see anything. Its the short line from the check valve that leaks from inside the cabin. The ither line from the check valve goes to the massive vacuum canister behind the left headilight.
                      Sent from my Honor phone by squinting at a browser
                        Oh I see, the one that goes into the firewall goes the hvac controls as I stated earlier. It operates the blend doors. If its leaking vacuum then when you turn the ac on itll work on defrost vents on all settings because thats the default position when vacuum is lost.
                          It shouldn't leak, but its not uncommon for the metal soup can to rust out or the line to it to crack. If you have automatic temperature control, the thermal blower lockout in the heater hose is also a common vacuum leak item. the check valve itself also can fail and make it act like a vacuum leak even when there is not one. ATC cars go to hot defrost when they lose vacuum, non-ATC cars just go to defrost. If it does this every time you accelerate, there is a leak or a problem with the check valve.
                          There should be one more small line through the firewall for the parking brake release. I believe that is closer to the steering column. That valve is another problem area.
                          When you checked the timing, was it steady or did the mark dance around?
                            When I tested the lines, I took out the check valve and tested the lines individually, the "soup can" is fine (takes a while to get a vacuum reading with a hand pump), but the line to the heater controls does leak. On the test run with it plugged I definitely got HOT defrost only, and mine has that automatic AC.
                            Now with that diagnosed, only vacuum ports left are the big one from the plastoc vacuum tree and the wierd green thing on the back left corner of the manifold.
                            As tested, the timing was stable, I suppose. I had to wirebrush the damn balamcer to see it at forst.
                              Make sure all the vacuum lines under the dash are pushed on all the way. Had to do that a couple of times with the actuators behind the ashtray that control all the vent positions.
                                The line going into the car branches back out to the thermal blower lockout. A leak there will look like a large leak inside the dash. I've never had the stuff in the dash seal perfectly though.
