Results 1 to 11 of 11
Thread: New from western ny
    Default New from western ny
    I'm pretty sure I've posted here before but I can not find my old post to bump and update. So here I am, a new person to panther platforms looking for advice.
    After years of horrifying luck with crap cars me and my lady are looking into a 2003+ grand marquis, Or vic, what ever. I've been doing boat loads of research and finding nothing telling me to steer clear of these things so here we are. I did look at a 94-95 a while back but it turned out to have a bad oil buring problem so I left it with its owner instead of buying. Now we have another opportunity to purchase a car and my eyes are set on a panther.
    Basically I'm just here for more convincing on buying one. So what do you all think?
    38,232
    Each generation has some gremlins. I think its the 03 or 03-04 that have timing tensioner issues. The early post-03 models also had weaker rear axle shafts that fail too early. I think that got fixed 2005? There are folks on here who know the late models far better than I do, so I'm sure the answers will come.
    in the meantime, welcome or welcome back, depending what you prefer
    18,772
    Get the newest one you can find. Even then it is soon ten years old!
    21,254
    Avoid 03/04 cars with less than 130K miles on them. The rear axles usually fail within that amount of mileage. Replacements typically last longer. 05 had some weird one-year stuff to it along with first half 06 IIRC. 04 also has some weird one-year stuff. 07+ generally got all the gremlins out other than the human factor. If the car was cared for (regular maintenance done when it was supposed to be done - INCLUDING transmission fluid and filter changes), they should be pretty good.
    GMN Regular
    Mar 2008
    Fredericton, N.B. Canada
    12,508
    Welcome! Check the frame for rust holes before purchase.
    '79 Continental Town Car
    '90 Crown Victoria LTD
    '94 Crown Victoria
    Member clutch47's Avatar
    Apr 2019
    385
    Welcome.
    There's a TON of information here and some fellas with deep knowledge. I learn something every time I come here..
    All FORD All The Time
    Thank you all for the warm re-welcome. I'll take into consideration everything I've read here when looking into my purchase. I was hoping the cable throttle years would have been turd free but that's really not a huge issue. Just another electronic that can fail and cost more to replace (which was my concern). Axle shafts are relitivly cheap as far as I remember from my time behind the counter so that honestly doesnt concern me. But again, thank you all! I'll continue to learn from this site
    Southern
    Apr 2013
    Columbia, SC
    847
    I would like to counter the thought on the 2003 models. Axle shafts can be easily required if the rear end is making noise by the axle shaft bearing or You see leakage. Otherwise it’s fine. And at this age and mileage, most have already been replaced. If anybody noticed it during the warranty., It was covered under a TSP. 2003‘s also had A recall for the factory tensioner‘s for the timing chains. You can see little painted hashmarks on the valve cover ends if it’s been done The majority of cars had this done. 2004s have a slightly different transmission than a 2003. They still used a 28 spline rear end like the 2003.
    I would pass over the 2005 models as there are questionable elements in terms of electrical components as well as transmissions. Everything was sorted and fixed for 2006. Ford change the electrical system halfway on 2005 models.
    2005 models did get upgraded to a 31 spline axles shaft. Unless you’re doing dragracing or something, there’s no reason to upgrade the axle shafts.
    I would drive a crown Victoria, grand Marquis, and a town car. See what you like. And purchase accordingly. Being that you’re in western New York, the capital of salt, you may want to consider heading south to acquire a less rusty vehicle to buy you time for longevity. Especially if you take vacations down on the Carolina coast, Georgia, or Florida, You can pick anyone of these up for not a lot of money with zero rust.
    -Nick M.
    Columbia, SC
    66 Squire, 89 Colony Park, 90 TC, 03 (2x) TC, 06 TC, 07 TC
    03 BMW 540iT, 05 GMC Yukon (tahoe)
    21,254
    If you can do the work yourself that is. If you have a shop do the work, have at least a grand on hand to pay them for an axle rebuild (all bearings & axles).
    GMN Regular
    Mar 2008
    12,508
    That would be a serious blow to the finances.
    '94 Crown Victoria
    21,254
    A good test drive with a highway run for at least a mile will tell you if the axles are shot. Humming/buzzing from the rear typically indicates that issue.
