steering shaft u-joint
    my steering shaft u-joint only has play up and down, but has no play side to side, should i be concered?
    its the rotational play thats more important. The up/down play is quite possibly where the shafts fit together. Its a double flat thing with a cross bolt, and it will have some play 90 degrees to the bolt. With the wheel straight the bolt should be horizontal so the play will be vertical.
