Air Bag Light
    Air Bag Light
    Does this mean there is a sensor that went bad? I drove through 2 floods in less than a week not too long ago. In the 2nd flood, the water was cresting the hood of the car. I noticed the day after the 2nd flood, my a/c compressor makes a squeaking noise. Last night I noticed the air bag light blinking; now it just remains lit up.
    Need to know the trouble code. Lots of things can turn that light on. OBD2 cars will read out the air bag codes through the diag port if you have the right scanner.
      Will do; I have an OBDII scanner for the MGM. THanks Gadget
        On startup it should flash whatever code is present. Otherwise a scanner will work but not all can access srs codes.
          right, has to be a scanner that can do SRS stuff. Basic obd2 usually won't.
            OBD Fusion Android App can read those. (In-app purchase per model/year)
            Forscan for Windows (free) can read those as long as windows can see the OBDII adapter.
              Forscan lite can be used with your phone (ios or android) and will read srs along with other modules. Its a great app and paired with an elm327 dongle its all you need.
