Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Cold start; hot no start?
    Poncho
    Mar 2009
    East TN
    97
    Default Cold start; hot no start?
    I want to get some opinions on what's going on with my ' 87 grand marquis. So here's the spill; the car starts fine cold and holds idle. Once it gets up to temperature and the thermostat opens up. If the car is turned off and started back up immediately after, it will turn over but not hold idle without giving it some gas. I'm under the suspicion it has something to do either with the evap canister system or the ignition module. What do you think? Thanks all for the suggestion!
    @Ryan.Madison68
    Have you tested your coolant temp sensor? It could be as simple as that.
    38,477
    Coolant temp sensor, or possibly the IAC getting stuck would be my guess too. If it was ignition, giving it some throttle wouldn't help.
    Poncho
    Mar 2009
    East TN
    97
    Thanks guys. I'll look into replacing the coolant temp sensor. It seems like most likely place. Is it in front of the motor near the rotor cap?
    @Ryan.Madison68
    18,840
    It will be on the passengers side of the motor. near the front on a pipe coming up and out of the lower intake. Two wire plug connected to it.
    When ordering dont mistake it for the one that is on the drivers side directly into the lower intake manifold. That is the one that goes directly to the replace engine light on your dash.
    Poncho
    Mar 2009
    East TN
    97
    I found this unplugged. Where does it connect to? Thanks 87GTVic
    @Ryan.Madison68
    18,840
    Looks like the plug for the replace engine coolant sensor just to the 2 o'clock on your circled portion.
    Poncho
    Mar 2009
    East TN
    97
    Okay. Does it connect on the metal stud right next to it on the valve cover? I tried to plug it back and it didn't fit.
    @Ryan.Madison68
    18,840
    If you still have the factory coolant temp sensor for the replace engine light it would fit right over the stud out of the unit.
    If your factory coolant temp sensor for the replace engine light was removed and an after market coolant temperature gauge was put into its place you wont have a place for the wire.
    I circled the sensor in yellow.
    Poncho
    Mar 2009
    East TN
    97
    That makes sense. Thanks!
    @Ryan.Madison68
    Poncho
    Mar 2009
    East TN
    97
    I swapped the coolant temp sensor, and it still is having trouble holding idle after a hot start. Any other suggestions? The IAC was recently replaced as well.
    @Ryan.Madison68
    5,406
    Sounds like you’ve covered the typical problem areas.
    Won’t hurt to set the base idle just in case someone before has screwed with it: https://www.muscularmustangs.com/idlereset.php
    Won’t hurt to check codes. If you don’t have a reader: http://www.fuelinjectedford.com/page13.html note that you don’t have a check engine light so you will need to use the test light or voltmeter.
    Vacuum leaks also do some weird things to these cars. Check those out.
    1988 Crown Vic Wagon - daily
    38,477
    There is also an air temperature sensor. #5 intake runner, driver's side, looks just about like the coolant sensor.
    Is the IAC a Motorcraft part? Some of the aftermarket ones don't seem to work right.
    Poncho
    Mar 2009
    East TN
    97
    Thanks for the tips, guys. I'll look into setting the base idle first since it seems pretty easy to do. I haven't been able to find the air temperature sensor. Anyone want to snap a shot of its location for me? I would greatly appreciate it.
    @Ryan.Madison68
    21,347
    Lower intake plenum... driver side of engine between the front 2 cylinders.
    38,477
    Poncho
    Mar 2009
    East TN
    97
    Hey guys. I'm still fishing for the culprit of the cold start idle idle / hot start no idle. And this part came to mind. It was swapped while I replaced a leaking fuel injector. One curious thing which may have no effect is the part had electrical taped wrapped around the bottom when it was removed and the replacement stock part had two inlets for that year though the next year one had one similar to mind so I opted for the next year one from AutoZone. Can anyone tell me what this part is and does? And could it be part of my problem? It came from inside the upper intake. As always thanks guys.
    @Ryan.Madison68
    18,840
    Looks the a PCV valve.
    Stock location for the PCV valve is way in the back of the lower intake.
    Dont believe there to be any difference between a two port PCV and the single one you have pictured above.
    The electrical tape is a just to make it fit more securely in its grommet. If it didn't fit snug there will be a vacuum leak.
    38,477
    its a PCV valve. Only one port needed. The aftermarket ones are a somewhat universal fit thing, it comes with an elbow with two holes. The small one is usually plugged, you cut the plug out if you need it. Or remove the elbow if your original did not have it.
    The grommets don't fit properly so you have to bulk up the PCV valve. use heat shrink tubing, it won't come apart and get sucked up into the valve.
    Mar 2007
    North Las Vegas Nevada
    2,316
    You may have a fuel pump overheating that will create a no start condishion so be prepaird to replace the fuel pump
