I had a similar issue when I had my 85 ltd but could never figure it out. When I turn the key itll turn over just fine but it takes a while to fire. Fuel pressure is fine around 35 psi after turning the key once and I swapped coils (msd crap from the po with the stock coil) and it started the same. I even tried holding the throttle open slightly to rule out the iac which also had no affect. Ive checked the ect and iat before and both were fine. The map sensor is original but I dont have any other issues really so I doubt its bad. Funny thing is when I had my vacuum lines routed incorrectly and the map sensor was getting a low vacuum reading it would start way easier but dump fuel lol. Anyone have any ideas?
