best way to coat new cast aluminum?
    I have a cast diff cover/girdle to go on Marauder.
    It is raw aluminum. With a polished bar.
    I do not have a powder coat setup available.
    I was thinking "hit it with some clear" or I could use color paint or tinted clear if it exists.
    So what is the best product or type of product?
    If it is brand new still send it to me. I will disassemble any plastic bits that won’t withstand the oven and powder coat it clear if you want. I have many other colors as well.
    It will require a couple bake cycles to first get any impurity’s out of the metal.
      That is a great offer.
      Yes it is new.
      Thank You
        No problem.
        I cleared the finned one ( gt500 style ) with high heat engine paint and it started to get milky looking and flake off in some areas after the few years of use I had on it. Which was around 6 years.
        I believe a full on paint job would have lasted longer than just applying clear in my case.
          It is a blue car... That or a grey color would work.
            I've had reasonable luck with the cast coat aluminum paint if you want the raw aluminum look. I did the intake, valve cover, and timing cover on the diesel and it looks surprisingly good. It also cleans up a lot easier than actual raw aluminum since the pores aren't open. Powdercoat would likely be tougher though.
              Dave,
              I don't know powder coating temps. Can I wrap the bolt threads with regular masking tape?
                Gadget is this the paint you referenced? Would be good to have some on the shelf.
                  DE1650 is the item number. This stuff.
                  https://shop.advanceautoparts.com/p/...1650/7140893-P
                    Originally posted by jaywish View Post
                    Dave,
                    I have high heat tape for masking such things. The piece I am concerned about is the pads that put pressure on the main caps. I forget if that is rubber.
                    Powder coating temps reach upwards of 500. Normally around 450.
                      yea the cast coat aluminum paint holds up real well on accy brackets and intakes. started using it when i built my engine in 2004.
                        Jay trusted me with his rear differential cover....
                        Did a blue inlay in the engravings:
                        Clear powder applies as a white before it melts:
                        And complete:
                        I think it gives it a nice subtle touch.
                          Looks nice. Seems to darken it a bit? Kind of reminds me of the paint on my Towncar's intake
                            sweet!
                              Excellent work as usual!
